Pinenut power consumpiton
I'm interested in real life data how much power PineNut need to operate.
My plan was to use them as solar powered ground moisture meters. They gonna wake up, and then report to base how wet/dry are ground, and go sleep back.
Also I'm not sure if i  gonna play with BT LE mesh or just use WiFi. Size of grass is around 10x20m.
I need some real life data to decide if making it solar powered is possible or not.
Lightbulb Product idea: Pinebank, 18650 multifunction power bank/speaker/light/etc cowsay 0 1,838 10-03-2025, 11:35 AM
Last Post: cowsay
  Optimizing Power Management on PinePhone with PostmarketOS ZaraAbbas 0 3,765 05-27-2025, 01:49 AM
Last Post: ZaraAbbas
  Replacement international plugs for 65W GaN Pine Power Cadair 1 4,141 05-20-2025, 10:20 PM
  Plans for higher Power PinePowers PMARC14 1 4,749 04-08-2025, 08:31 PM
Last Post: colajuices
  Pine Desktop PowerSupply wont power on BSharp 6 8,298 01-07-2025, 08:04 AM
Last Post: skare
  Help with high voltage power supply setup for electrospinning? namarang 2 5,291 10-13-2024, 09:38 AM
Last Post: zetabeta
  Firmware Update for PinePower Desktop Power Cycling Issue TimothyRodriguez 1 3,097 05-03-2024, 12:53 AM
Last Post: Pavlos1
  Link USB power strips for a cluster? shanefe 1 3,093 04-02-2024, 11:11 PM
Last Post: evilbunny
  [Article] Star64 JH7110: Power Up the Display Controller with U-Boot Bootloader lupyuen 0 2,751 09-02-2023, 10:13 AM
Last Post: lupyuen
  power/battery usage on risc-v vs arm64? zetabeta 1 3,465 08-28-2023, 01:23 AM
Last Post: alphonso
