PostmarketOS Camera and ffmeg
I'm looking a way to capture picture from rear camera with ffmpeg, I have tried multiple ways to configure camera with media-ctl with no luck Sad
below output from media-ctl -d /dev/media1 --print-topology
Media device information ------------------------ driver          sun6i-csi model          Allwinner Video Capture Device serial          bus info        platform:1cb0000.csi hw revision    0x0 driver version  5.15.13 Device topology - entity 1: sun6i-csi (1 pad, 2 links)             type Node subtype V4L flags 0             device node name /dev/video2         pad0: Sink                 <- "ov5640 4-004c":0 [ENABLED]                 <- "gc2145 4-003c":0 [] - entity 5: ov5640 4-004c (1 pad, 1 link)             type V4L2 subdev subtype Sensor flags 0             device node name /dev/v4l-subdev0         pad0: Source                 [fmt:SBGGR8_1X8/1280x720@1/30 colorspace:srgb xfer:srgb ycbcr:601 quantization:full-range]                 -> "sun6i-csi":0 [ENABLED] - entity 7: gc2145 4-003c (1 pad, 1 link)             type V4L2 subdev subtype Sensor flags 0             device node name /dev/v4l-subdev1         pad0: Source                 [fmt:SBGGR8_1X8/1280x960@1/60 field:none colorspace:raw]                 -> "sun6i-csi":0 []
and when I trying to execute ffmpeg -s 1280x720 -f video4linux2 -i /dev/video2 -vframes 1 selfie.jpg got in results error
ffmpeg version 4.4.1 Copyright (c) 2000-2021 the FFmpeg developers   built with gcc 10.3.1 (Alpine 10.3.1_git20211027) 20211027   configuration: --prefix=/usr --enable-avresample --enable-avfilter --enable-gnutls --enable-gpl --enable-libass --enable-libmp3lame --enable-libvorbis --enable-libvpx --enable-libxvid --enable-libx264 --enable-libx265 --enable-libtheora --enable-libv4l2 --enable-libdav1d --enable-postproc --enable-pic --enable-pthreads --enable-shared --enable-libxcb --enable-libsrt --enable-libssh --enable-libvidstab --disable-stripping --disable-static --disable-librtmp --enable-libaom --enable-libopus --enable-libsoxr --enable-libwebp --enable-vaapi --enable-vdpau --enable-vulkan --disable-debug   libavutil      56. 70.100 / 56. 70.100   libavcodec    58.134.100 / 58.134.100   libavformat    58. 76.100 / 58. 76.100   libavdevice    58. 13.100 / 58. 13.100   libavfilter    7.110.100 /  7.110.100   libavresample  4.  0.  0 /  4.  0.  0   libswscale      5.  9.100 /  5.  9.100   libswresample  3.  9.100 /  3.  9.100   libpostproc    55.  9.100 / 55.  9.100 [video4linux2,v4l2 @ 0xffff9b534670] ioctl(VIDIOC_STREAMON): Broken pipe /dev/video2: Broken pipe
I'm using main version of postmarketos
any ideas?
The megapixels contributor does occasionally mention ffmpeg in his blogs, so maybe looking there or filing an issue on the tracker could point you in the right direction.
Blog: https://blog.brixit.nl/tag/phones/
Tracker: https://gitlab.com/postmarketOS/megapixels
PPv1.2a running PMOS ... almost a daily driver!
  Would another camera work in the PP? nelstomlinson 2 5,138 11-11-2021, 06:25 PM
Last Post: nelstomlinson
Sad Have I got a broken camera module? AKD251 2 5,114 11-07-2021, 11:12 AM
Last Post: beta-user
  camera firmware problems kqlnut 25 43,641 09-02-2021, 07:49 PM
  camera + megaixel and strange behavior streak 0 3,394 06-02-2021, 06:45 AM
Last Post: streak
  Pinephone camera thread ryo 8 14,963 05-29-2021, 03:21 AM
Last Post: ryo
  Camera clicking sound unsatisfactory212 2 5,701 05-07-2021, 02:57 PM
Last Post: megous
  Main Board Swap: Camera connector problems tyha 5 10,628 11-19-2020, 06:25 PM
Last Post: pajux
  New PinePhone PostmarketOS CE -- No second display output audidiablo 3 7,738 09-22-2020, 05:11 AM
Last Post: Arehandoro
  Camera with stange colors zykran 0 2,949 09-18-2020, 10:05 AM
Last Post: zykran
  camera question xinyiman 3 8,036 08-31-2020, 05:50 AM
Last Post: Veraendert
