Sata HD stopped booting
I have a RockPro64 running Ubuntu 4.4.190-1233-rockchip-ayufan-gd3f1be0ed310. It boots from emmc and has a hard disk attached via SATA.
After working fine for a long time, since last week the hard disk doesn't seem to be recognized. It doesn't show up in `fdisk -l` for example and isn't mounted anymore.
If I plug it into another laptop the drive mounts and is visible so I don't think it's dead. dmesg contains `PCIe link training gen 1 timeout!` which may be related and the last time it successfully mounted the linux-firmware package was updated via apt from 1.187.25 to 1.187.26. The older version no longer seems to be available to rollback to so unsure if related.
Anybody seen this before or know what to do here?
(03-10-2022, 05:11 PM)db579 Wrote: I have a RockPro64 running Ubuntu 4.4.190-1233-rockchip-ayufan-gd3f1be0ed310. It boots from emmc and has a hard disk attached via SATA.
Not sure how familiar you are with Linux but a bit of googling should yield some answers. In the meantime have a read up on this https://www.maketecheasier.com/downgrade-kernel-linux/
@Rocklobster  thanks very much for the hint. I'd completely missed that there was a kernel upgrade in there as well. Downgrading was slightly different than in your link since it's u-boot rather than grub I commented the running kernel out of `/boot/extlinux/extlinux.conf` and rebooted and the drive is mounted again fine.
So it seems `4.4.167-1213-rockchip-ayufan-g34ae07687fce` works fine but ` 4.4.190-1233-rockchip-ayufan-gd3f1be0ed310` does not.
  (real) Mainline U-boot finally works on SPI, boots SATA, throw away your SD cards NOW aleksei 0 12,884 06-21-2025, 06:21 AM
Last Post: aleksei
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 226,331 09-25-2023, 12:46 AM
Last Post: ChriChri
  RockPro64 Stopped working WarpLover 5 9,406 02-06-2023, 10:10 AM
Last Post: diizzy
  Booting my RockPro64 from NVMe drive PsySc0rpi0n 4 10,605 05-11-2022, 02:35 PM
Last Post: PsySc0rpi0n
Exclamation need help booting off USB 3.0 HDD/SSD idontgetit 1 5,957 10-29-2020, 04:50 AM
Last Post: t4_4t
  Rockpro64 with PCI FC Card - Not booting (Sometimes) MSteam 1 4,996 10-25-2020, 07:42 PM
Last Post: MSteam
  fan continously runs on kernel 5.8 but I need to use 5. kernel for PCIe sata card GreyLinux 4 10,124 10-20-2020, 10:52 AM
Last Post: GreyLinux
  RockPro64 SSD Expansion Board/SATA Shield as0zial 5 12,943 10-18-2020, 08:05 PM
Last Post: revoman
  4pin Connector for dual SATA m.ekstrom 4 10,248 07-28-2020, 07:07 AM
Last Post: mabs
  Defective? PCI-E -> SATA card no work good unregisteredidiot 11 22,277 02-19-2020, 09:08 AM
Last Post: fysa
