Cases and Enclosure Question
#21
(01-23-2016, 01:08 PM)tllim Wrote:
(01-23-2016, 11:05 AM)By-Jokese Wrote: @brf does this work?
Well, it certainly is a good start.  It is, unfortunately, only two-dimensional, so I can design something and adjust the other parameters when I get a board I can measure with a ruler.  I'll give it a shot.
noted, we will provide more info on next 2-3 days.
Well done on that last wood case photo, looks really good!
(01-24-2016, 05:31 AM)carlosviansi Wrote: Well done on that last wood case photo, looks really good!
Thank you, Carlos !
Since this is a computer called  "Pine" ,  better, the enclosure to be wooden ...  Wink
I n addition, I'm thinking that for every enclosure that do ...
I will donate a small amount to "seed" a tree   Idea
Just don't call "Pine Box", this is not a good name. Just google and you will know.
I know that I have seen a Lego enclosure for the pine 64 in a video somewhere has someone replicated it yet?
If so can you post a close up picture of it without the pine 64 inside?
Thank you!
It's been over a week, any word on when an STL file will be available?
(01-25-2016, 10:10 AM)tllim Wrote: Just don't call "Pine Box", this is not a good name. Just google and you will know.
Sure !!!!  jajajaa!!   Big Grin
How many cases will there be for sale at the Pine 64 shop?
Since the latest update, which included images of cases/enclosures, people are wondering what has happened to the clear open case with 4 metal struts? (see below):
http://bit.ly/1nMW0mD
what kind of heat dissipation will be needed? for the molded cases announced is there is no ventilation at all, and under load (like HD video decoding) and I'm concerned this will be too much heat for them, causing instability and/or reducing the life of the board.
that stretched wood case looks great though
Photo C4 Labs Pine 64 Cases (Standard & LCD) Bluphire 95 243,337 11-02-2020, 08:43 PM
Last Post: Little_Johnny
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 33,206 10-12-2018, 03:08 PM
Lightbulb Perfect ABS Plastic Server Enclosure from Radio Shack MarkHaysHarris777 14 52,269 09-11-2017, 11:39 AM
Last Post: stuartiannaylor
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 10,741 06-17-2017, 01:29 AM
Last Post: pfeerick
  Nostalgic enclosure VHS carlo318 4 13,158 03-05-2017, 04:56 PM
Last Post: carlo318
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 10,115 02-12-2017, 10:17 PM
  Enclosure for flush-mounting the 7" touchscreen Learnincurve 9 21,476 02-07-2017, 08:45 PM
Last Post: Bluphire
  Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO* Bluphire 12 39,547 01-06-2017, 03:15 AM
Last Post: Learnincurve
  Tablet Enclosure Vachtra 11 32,098 12-20-2016, 07:17 AM
Last Post: Toriless
Rainbow PineA64 Home-Brew card-board Play Box for Android & LCD Enclosure MarkHaysHarris777 9 28,970 11-01-2016, 06:23 PM
