Replace PPP sim card/sd card slot hardware
Looking for replacement for SA-2202-112 25-pin Micro-SIM and TF slot as referenced from PPP parts list.
PPP will not read my consumer cellular sim card and it is difficult to insert or remove sd cards.  It used to read sim card fine and I could make phone calls, sms, and mms using manjaro-phosh.  Now nothing.   No software fixes work so it must be the hardware.  Perhaps too many inserts/removals.
I can't find replacement on PPP spare parts site.  Search for part doesn't pick up anything on internet.  Amazon has some slot hardware but nothing looks simillar.
Anyone found a hardware source?  Anyone changed one out successfully?
thanks,     tom kosvic
(03-03-2022, 09:10 AM)tckosvic Wrote: Looking for replacement for SA-2202-112 25-pin Micro-SIM and TF slot as referenced from PPP parts list.
thanks,     tom kosvic
Additionally,  the slot hardware is not listed in PPP spare parts website.  I left a message at pinephone info asking them for a purchase recommendation.
If you ever get anywhere with this, a video would be great as this has been a long standing problem for many people. Also sourcing information. Kudos to you for taking this on.
Cheers!
Cheers,
TRS-80
Protocols, not Platforms
(03-03-2022, 01:06 PM)TRS-80 Wrote: If you ever get anywhere with this, a video would be great as this has been a long standing problem for many people.  Also sourcing information.  Kudos to you for taking this on.
Cheers!
I posted an email to pinephone support asking for a source to purchase a new sim/sd card holder slot hardware.  I received an email back saying that they had forwarded my question to parts supply dept.  That was 3 days ago and no answer yet.  I sent them another email asking them to wake those guys up.  No answer
tom kosvic
[Image: 110859596.png?v=052120.1100]
Maybe this will work as a replacement?
It's no thte SA-2202-112 25-pin Micro-SIM and TF slot, but it looks like it might be a substitute part.
https://www.mouser.com/new/molex/molex-m...connector/
Can't find a place to buy referenced molex sim/sd card holder in numbers less than 1000.  Amazon looks to sell small numbers but is out ot them with no info as to when they'll be back in stock
  How to remove the sim card liberty1234 7 13,613 07-17-2024, 09:57 AM
Last Post: Blackheart
  Anyone yet received replacement sim/sd card holder tckosvic 19 26,373 06-16-2023, 12:20 PM
Last Post: fxc
Photo My PinePhone Pro does not read the micro SD card at all. tux_life 7 10,179 03-26-2023, 02:55 AM
Last Post: tux_life
  PinePhone Pro Motherboard with sim card holder tckosvic 1 4,124 08-22-2022, 06:42 PM
  Replace Pogo Pins / Melted Pogo Pins fix magdesign 0 4,543 08-01-2022, 02:49 PM
Last Post: magdesign
  Warning!!- sim card adapter destroyed my sim card holder on my pine phone pro ANDROID2468 11 19,306 06-15-2022, 02:32 AM
Last Post: fxc
  How to access the hardware privacy switches? Pinoideae 3 5,779 02-09-2022, 10:45 PM
Last Post: bcnaz
  SD Card insertion depth nristen 4 7,510 02-03-2022, 01:27 PM
Last Post: nristen
  Bent SD card pin bhboyle 5 9,799 02-03-2022, 09:54 AM
Last Post: kqlnut
  SD card slot specs frimmel 3 7,239 01-27-2022, 09:48 PM
Last Post: bcnaz
