Problem updating
I have been running Mobian bookworm Phosh on my pinephone. Lately, when updating by using the software update under settings I have been receiving the message "unable to install updates. Prepared update not found: /var/lib/PackageKit/prepared-update". I also tried to update using the terminal and sudo apt update followed by sudo apt install. No luck. Am I missing something? In the past Mobian would post updates every week and the updater under settings worked great. Any help or ideas would be appreciated. Thanks
do it from the command line
Do you still have Internet access? It seems there is a problem with the last version of network manager.
(02-21-2022, 06:40 PM)gilwood Wrote: I have been running Mobian bookworm Phosh on my pinephone. Lately, when updating by using the software update under settings I have been receiving the message "unable to install updates. Prepared update not found: /var/lib/PackageKit/prepared-update". I also tried to update using the terminal and sudo apt update followed by sudo apt install. No luck. Am I missing something? In the past Mobian would post updates every week and the updater under settings worked great. Any help or ideas would be appreciated. Thanks
I heard that is a known problem,  and that they  "are working on it"...
For my daily driver I am just going to ride this out,  everything I use is working.
For my test phone I flashed the Feb. 20 release,  the basics are all working, but I have not dug too deep into it yet.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
Thanks for the info. So far my last update, which worked, is running OK. I will follow your guidance and be patient with the team to provide the solution. I have been very impressed so far at the rate of Mobian development.
I have been updating from the command line and everything seems to be working. Use the tip provided.
sudo apt update && sudo apt upgrade -y -y
  Mobian MMS/SMS text problem bcnaz 16 40,069 06-23-2026, 06:53 AM
Last Post: mehdy
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 18,401 08-31-2023, 12:38 PM
Last Post: vusra
  MODEM - Usb problem & couldn't query SIM slots: QMI protocol freelectro 5 11,082 06-06-2023, 06:36 AM
Last Post: freelectro
  Battery problem with a Pinephone keyboard and Mobian elode 2 5,765 12-22-2022, 07:10 PM
Last Post: acid andy
  No audio on calls after updating today Zebulon Walton 10 15,784 12-12-2022, 09:55 PM
Last Post: BaronAlbatross
  Gnome Web CSS problem? jojuma 0 2,144 05-27-2022, 11:43 AM
Last Post: jojuma
  Problem with wifi kubussz 0 2,205 04-02-2022, 12:57 PM
Last Post: kubussz
  Updating Phosh from Gitlab ragreenburg 2 4,993 10-07-2021, 08:35 AM
Last Post: ragreenburg
  Updating old Mobian installation? SocialNetworkingWasAMistake 1 3,417 09-14-2021, 03:41 PM
Last Post: bcnaz
Bug Wake up from charging problem j4n3z 11 18,914 02-25-2021, 03:53 PM
Last Post: j4n3z
