Error Updating
today unable to update
Manjaro-ARM-Plasma latest release
sudo pacman -Syu
error:failed to commit transation (conflicting files)
packagekit: usr/lib/systemd/system/sytem-update.target.wants/packagekit-offline-update.service exist in filesystem (owned by pinephonepro-manjaro-tweaks)
Errors ocurred, no packages were upgraded.
(02-19-2022, 10:01 AM)Emilio Wrote: today unable to update
sudo pacman -Syu
Not much help to you but Manjaro-phosh updated fine today using "sudo pacman -Syu".  Perhaps located problem to your installation rather than the system.
tom kosvic
sudo pacman -Syu
tom kosvic
I don't care much. I am learning. Tomorrow I will burn  a new release of plasma. Do not install Phosh because in the release they say gps is not working properly and I am doing trials with gps, osmdscoutserver and puremaps offline and pretty well except mimic voice. Tomorrow I will do more trials. Thanks a lot
  How Can I Fix This Repo Error dorkydev 1 2,200 11-09-2024, 06:55 AM
Sad Couple of problems updating Ctrl_Amiga_1070 12 12,956 08-19-2023, 05:12 PM
Last Post: Ctrl_Amiga_1070
  Phosh Updating - Battery Charge Indicator - Jittery Settings - Display Usability ArchiMark 4 5,527 05-28-2023, 07:00 AM
Last Post: ArchiMark
  Offline Updates Error dgiffin 7 11,107 06-30-2022, 02:19 PM
Last Post: magdesign
Question System Updates: "unexpected error" Greendrake 6 10,060 03-05-2022, 05:15 AM
Last Post: Greendrake
  No update PGP, Error Solved iopser 2 4,411 02-01-2022, 07:53 AM
Last Post: iopser
