No update PGP, Error Solved
Helloo
Today finallyyy a get this peace of hardware.
And when i try to update. oo error ... and error after error.
Well after reading researching, 2 h later i figure out one way to solve the issue.
The error pgp refer to the sig files, so i erase the sig file.
1 file error: archlinux-keyring-20220118-1any.pkg.tar.xz.sig or some like that.
2 file error: archlinuxarm-keyring-20140119-1any.pkg.tar.xz.sig or some like that.
make sudo pacman -Syu, make error happen, but dont erase the files. go to
/var/cache/pacman/pkg/ an erase the .sig, this is important.
and them install the package
sudo pacman -U /var/cache/pacman/pkg/package1.pkg.tar.xz
and try if you get another error like me, them
sudo pacman -U /var/cache/pacman/pkg/package2.pkg.tar.xz
After that you can try to install openssh or one prog o just try and update.
For me this solve this litlle problem. and system update DONE.
ello
Saludos.
Actually this would make you install anything from the repositories, without validation of the signatures. Making you vulnerable to viruses and hack attacks.
I would suggest to repear your keyrings instead. I posted a how to here: https://forum.pine64.org/showthread.php?...#pid105737
For some other users it was fixed by running post install script:
sudo pinephonepro-post-install
It also contains the lines:
# Pacman Init pacman-key --init pacman-key --populate archlinuxarm manjaro manjaro-arm
which will resync and repopulate the keys.
ok.. thanks
i know this is not the way, but
i already try this:
pacman-key --init
and refresh and other command but the same result error and error.
this one sudo pinephonepro-post-install
didn't find it... i'll keep this info.
i just install 2 packages without the .sig
well. i guest what i did was a dumb move.
i'll try to reinstall with the sig.. let see what happen.
thanks Luziferus for the info.
  How Can I Fix This Repo Error dorkydev 1 2,321 11-09-2024, 06:55 AM
  Arch SXMO Stopped Booting After A Megi Linux Update. mburns 0 2,077 11-07-2023, 09:52 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 2,174 10-14-2023, 11:57 AM
Last Post: mburns
  Cannot update new PinePhone Pro bent 6 10,098 05-15-2023, 02:43 PM
Last Post: alaraajavamma
  No display on early boot after Manjaro update robocone 0 2,389 07-07-2022, 05:47 AM
Last Post: robocone
  Offline Updates Error dgiffin 7 11,282 06-30-2022, 02:19 PM
Last Post: magdesign
  Manjaro Plasma Beta 11 sleep issue after 3/22 update Fred Zyphal 6 9,864 05-22-2022, 12:37 PM
  Manjaro update, no boot, just noise. wilmarcdw 2 4,311 05-09-2022, 07:24 AM
Last Post: wilmarcdw
Question System Updates: "unexpected error" Greendrake 6 10,213 03-05-2022, 05:15 AM
Last Post: Greendrake
  Manjaro-phosh beta 22 release won't boot after update tckosvic 1 3,623 02-28-2022, 09:46 AM
Last Post: tckosvic
