how to get rid of heavy distortion from the speakers?
Greetangs bredren,
It used to be that
[font=monospace][color=#000000]# amixer sset 'DAC Stereo Enhancement' 0[/color][/font]
Vastly reduced distortion from the speakers. It now only returns
[font=monospace][color=#000000]amixer: Mixer attach default error: Host is down[/color][/font]
and distortion is pretty bad atm. What to do?
(02-15-2022, 11:21 AM)stozi Wrote: Greetangs bredren,
It used to be that
so I double checked the amixer commands that used to lower the 'DAC Stereo Enhancement' setting. If run as a normal user, amixer returns a different error message, which hints at a missing control entry for that DAC enhancement.
returns:
amixer: Unable to find simple control 'DAC Stereo Enhancement',0
This can be confirmed by listing all available simple controls
amixer scontrols
which now only returns two entries:
Simple mixer control 'Master',0
Simple mixer control 'Capture',0
Seems like the 'DAC Stereo Enhancement' control entry no longer exists. I'll dig a little deeper into this, but at least I think I found the general problem :D
UPDATE:
Ok, I think I got it to work:
amixer -c 0 sset 'DAC Stereo Enhancement' 0
does the trick.
t. RotatingNut
you're a legend, thanks!
  Up-firing speakers!!! mamboman777 6 10,921 07-28-2021, 02:54 PM
Last Post: mamboman777
  If booted with headphones in, sound comes from them and speakers stozi 6 11,058 06-11-2021, 01:27 AM
Last Post: dsimic
  Pine book Pro Speakers bcnaz 27 48,447 05-20-2020, 07:05 AM
Last Post: TDC_PBP
  Issues connecting bluetooth headphones and speakers jamathis 2 6,593 12-01-2019, 11:21 AM
Last Post: jamathis
