high battery drain on suspend/poweroff
I recieved my PineBook Pro a week ago. I use Manjaro ARM with KDE (the image that came with the laptop)
I noticed very high battery drain on suspend with systemctl suspend (50% ~8 hours) and even when powered off with sudo shutdown (20% ~20hours).
I'm very worried. Do you think my unit is faulty ?
Thank you
no that's normal. the suspend state available to OS options using mainline uboot (like Manjaro) can currently only offer S2 sleep state, rather than the S3 that people often associate when they think of suspending a computer.
you can achieve S3, though, but it requires you to switch to BSP uboot, and downgrade your kernel, then edit sleep.conf.
(05-11-2021, 02:30 PM)tophneal Wrote: no that's normal. the suspend state available to OS options using mainline uboot (like Manjaro) can currently only offer S2 sleep state, rather than the S3 that people often associate when they think of suspending a computer.
Thank you for you answer. Is it also normal for the battery to drain when powered off ?
(05-11-2021, 03:19 PM)wiz Wrote: Thank you for you answer. Is it also normal for the battery to drain when powered off ?
not enough that should be noticeable. something to keep in mind though is that (last i recall) manjaro kde has the power button set to enter s2 sleep, and not actually turn off the pbp(this can be changed in the settings.) so it can look like you're turning off your pbp, but it's not actually off.
(05-11-2021, 01:41 PM)wiz Wrote: Hi,
Thank you
the s2ram issue is very painful on PineBook Pro. I could get it working with Tow-boot installed to SPI memory and changing sleep.conf file. With Tow-boot install to emmc or sd the laptop didn't resume.
I tried out tow-boot, when I did, it did work OK viz s3 (on SD) but not as good as BSP (more draw)
Then there was an update, and it did not awaken from sleep (IIRR)
BTW, s3 is called suspend in dmesg,,, ie dmesg|grep suspend
  Pinebook Pro drains ny battery after shutting it off Tongman 4 7,148 12-01-2022, 02:50 AM
Question High Pitch Noise Coming From Pinebook Pro User 11436 60 140,619 11-16-2022, 02:51 PM
Last Post: kebab
  Battery Frost1776 1 3,292 10-07-2022, 04:17 PM
Last Post: LivingLinux
  Pinebook Pro freezes when running on battery petaramesh 5 7,821 09-22-2022, 12:43 AM
Last Post: petaramesh
Heart Now better battery life or power management? KC9UDX 5 7,075 09-09-2022, 08:13 PM
  Very low battery (but charging) causes boot failures Phillip Bell 7 11,157 02-22-2022, 11:20 AM
  NVMe SSD and battery life? dieselnutjob 3 7,432 04-19-2021, 01:55 PM
Last Post: slyecho
  Power consumption and suspend to ram robt 33 73,889 11-30-2020, 04:32 PM
  [AUG 2020] PBP Battery Issue (?) mercato 7 13,545 09-22-2020, 12:10 AM
  No battery or wifi after poweroff Goin2mars 3 7,840 09-19-2020, 09:58 AM
Last Post: xmixahlx
