New phone - Only red/green light. No boot.
I have a new pine64 and once unpackaged, removed battery plastic, attempted to power on. Only red/orange indicator appears, black screen. Inserted micro sd with mobian image and got a green indicator but still black screen.
Would really love to get this bad-boy up and running! Thanks!
(02-01-2022, 05:39 PM)migaligaz Wrote: I have a new pine64 and once unpackaged, removed battery plastic, attempted to power on. Only red/orange indicator appears, black screen. Inserted micro sd with mobian image and got a green indicator but still black screen.
I have the same problem. Completly new phone aswell.
After searching around i think the problem is with the battery beeing completly discharged, and the phone beeing unnable to charge the battery while beeing turned off.
( I dont know if this is the case, or the whole story )
If you have a seccond device or some way to charge it, maybe that will work.
Quote:If the battery is fully drained U-Boot might fail to boot any installed operating system on the eMMC and microSD card due to a bug.
If that's the case please start your phone in Maskrom mode and let it charge in that for a few hours. To do that:
  • Remove any microSD card from the phone
  • Hold the "RE" button underneath the back cover of your Explorer Edition (or shorting the bypass contact points on the Developer Edition)
  • Connect the phone to an USB port of a computer, while still holding the button
  • Check if the phone in Maskrom mode appears in the output of the Linux command lsusb on the computer (if the device disappears again please use a different cable)
  • Let the phone charge for multiple hours
Note: If that didn't work, try to remove the battery and the USB cable and hold the power button for a few seconds and then insert the battery again, before retrying the procedure.
From the PPP Wiki. Hopefully that helps, I found just using a 5V 3A charger and waiting a bit also did it for me.
  Can't detect the phone's battery shanewilliam 2 2,002 05-17-2026, 04:49 AM
Last Post: drh
  pine phone konaphone 2 2,359 10-23-2025, 07:53 AM
Last Post: mikehenson
  Goolge banning Sideloaded APKs in 2026, Year of the really Linux Phone? biketool 1 5,937 08-27-2025, 11:59 AM
Last Post: zetabeta
Exclamation Pinephone Pro wont boot to anything! Supervisor 5 4,675 08-18-2025, 06:15 PM
  No rk2aw boot menu jebez 7 5,480 07-09-2025, 07:12 AM
Information Fix PinePhone Pro when unable to boot due to drained battery butjar 8 17,660 03-13-2025, 08:40 PM
Last Post: pcb
  Bluetooth for phone calls Stray 2 3,780 02-25-2025, 12:22 PM
Last Post: Stray
  PinePhone doesn't boot anymore lapin 3 3,969 09-13-2024, 10:09 AM
Last Post: lapin
  How to boot from SD card in PPP joespodie 2 5,054 08-02-2024, 02:49 PM
  Can't boot Pinephone Pro into Factory Test Build for Hardware Checking jydoxcen 3 4,717 02-17-2024, 04:04 AM
Last Post: fxc
