SD Card insertion depth
I want to verify how far an sd card should be inserted into the pine phone pro...
Please comment if the SD card depicted is inserted too deeply.
[Image: ppp-sd-card-insertion.png]
(02-01-2022, 12:02 PM)nristen Wrote: I want to verify how far an sd card should be inserted into the pine phone pro...
That looks dead right to me.
1) Exactly the same as an Evo+ in mine
2) I can also just see the ends of half the SIM springs on the left of the SDcard in the pic (if that makes sense)
Looks ok to me.  I do have a problem getting sd card into slot.  Doesn't fit cleanly like on pinephone.  Requires some jiggling around and some significant force.  I wonder if something is out of alignment and perhaps could be adjusted a little.
Anyone else have same problem?
tom kosvic
I always just push it in until it bottoms in the socket... (and straight)
I opened one of my phones and compared it to your photo, yep, that is how it looks.
I have never had a problem with the socket, ----> I have swapped sd cards hundreds of times since the old Brave Heart days.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(02-02-2022, 08:02 AM)bcnaz Wrote: I always just push it in until it bottoms in the socket...  (and straight)
Thank you everyone for the responses.  I was concerned that I was either pushing the card in too far or had damaged the slot somehow.  As it turns out, I took the suggestion in another thread to try using Etcher to write the image to the sd card which indicated a verification problem after the write was done.
I switched to another SD card which worked beautifully... I was able to boot successfully into Mobian after holding the power button down for 5 seconds.
  How to remove the sim card liberty1234 7 13,554 07-17-2024, 09:57 AM
Last Post: Blackheart
  Anyone yet received replacement sim/sd card holder tckosvic 19 26,306 06-16-2023, 12:20 PM
Last Post: fxc
Photo My PinePhone Pro does not read the micro SD card at all. tux_life 7 10,159 03-26-2023, 02:55 AM
Last Post: tux_life
  PinePhone Pro Motherboard with sim card holder tckosvic 1 4,122 08-22-2022, 06:42 PM
  Warning!!- sim card adapter destroyed my sim card holder on my pine phone pro ANDROID2468 11 19,270 06-15-2022, 02:32 AM
Last Post: fxc
  Replace PPP sim card/sd card slot hardware tckosvic 5 9,499 03-13-2022, 12:20 PM
Last Post: tckosvic
  Bent SD card pin bhboyle 5 9,772 02-03-2022, 09:54 AM
Last Post: kqlnut
  SD card slot specs frimmel 3 7,223 01-27-2022, 09:48 PM
Last Post: bcnaz
