Not possible to make a bootable SD
How not agree with you! PhoenixCard is a crap, can't really understand why a development board that can be used with linux and android should use a proprietary tool to flash OS images.
Hi Outlaw,
I understand you're not lucky with the situation, but please do not use infect my topic with your swearing! Your post doesn't bring me any closer to a solution. If you want to swear and complain, please open your own topic.
Regards,
Mischa
Well there ya go!  Bit of a hunt around - tried a teeny little USB MicroSD reader - and it worked (from Phoenixcard writer in Windows) !
Got it booting (or seeming to boot) now with Android on the Pine supplied TouchPanel...  Screen flashed Android 64 bit about 10 times - now there's like 800 tiny white vertical lines across the screen.... does that mean anything?
edit : got it booted into Android now... not pretty... Is this my only option if I want to use the 7" Touchpanel? If I'd known there was no Linux support for the Touchpanel - I wouldn't have bought it with my 2 x Pine 2 GB boards... This project was always advertised as an Android AND Linux 64 bit platform...
sorry Mischa if you're offended by my use of coarse language - you probably won't much like my avatar picture either...
  How to Make a Pine with Android 7.0 Stay on All the Time? Bob123456789 3 8,031 04-05-2017, 01:12 PM
Last Post: Bob123456789
  Creating bootable SD card on Mac OS X colinj 13 34,460 01-24-2017, 03:03 AM
Last Post: MarkHaysHarris777
  anyone make pine64 lcd hdmi work simultaneously bokeer 4 11,103 12-11-2016, 05:57 PM
Last Post: Luke
  how do you make Android image for LCD Panel nath16 3 8,000 06-09-2016, 07:23 PM
  Bootable SD card with android image mcs_dodo 7 13,251 05-18-2016, 09:38 AM
  Steps to create Android bootable micro-SD card khgoh 0 5,779 01-07-2016, 07:56 PM
Last Post: khgoh
