slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64)
#31
I connected to a big Sony TV.
No output.
Unplugged the HDMI cable and plugged it back in.
I have HDMI !
Booting up before unplugging and replugging:-
root@quartz64:/var/log# cat Xorg.0.log
[    43.959]
X.Org X Server 1.20.13
X Protocol Version 11, Revision 0
[    43.959] Build Operating System: Slackware 15.0 Slackware Linux Project
[    43.959] Current Operating System: Linux quartz64 5.16.0-rc4 #1 SMP PREEMPT Sun Dec 5 23:15:25 U4
[    43.959] Kernel command line: root=/dev/mmcblk0p2 ro rootwait rootfstype=ext4 init=/sbin/init lo8
[    43.959] Build Date: 30 July 2021  08:16:48PM
[    43.959]
[    43.959] Current version of pixman: 0.40.0
[    43.959]    Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
[    43.959] Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    43.960] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Dec  7 12:35:18 2021
[    43.964] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    43.964] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    43.972] (==) No Layout section.  Using the first Screen section.
[    43.972] (==) No screen section available. Using defaults.
[    43.972] (**) |-->Screen "Default Screen Section" (0)
[    43.972] (**) |   |-->Monitor "<default monitor>"
[    43.974] (==) No monitor specified for screen "Default Screen Section".
        Using a default monitor configuration.
[    43.974] (**) Option "BlankTime" "0"
[    43.974] (**) Option "StandbyTime" "0"
[    43.974] (**) Option "SuspendTime" "0"
[    43.974] (**) Option "OffTime" "0"
[    43.974] (==) Automatically adding devices
[    43.974] (==) Automatically enabling devices
[    43.974] (==) Automatically adding GPU devices
[    43.974] (==) Automatically binding GPU devices
[    43.975] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    43.975] (WW) The directory "/usr/share/fonts/local" does not exist.
[    43.975]    Entry deleted from font path.
[    43.975] (WW) The directory "/usr/share/fonts/CID" does not exist.
[    43.986] (==) FontPath set to:
        /usr/share/fonts/misc,
        /usr/share/fonts/TTF,
        /usr/share/fonts/OTF,
        /usr/share/fonts/Type1,
        /usr/share/fonts/75dpi/:unscaled,
        /usr/share/fonts/100dpi/:unscaled,
        /usr/share/fonts/75dpi,
        /usr/share/fonts/100dpi,
        /usr/share/fonts/cyrillic
[    43.986] (==) ModulePath set to "/usr/lib64/xorg/modules"
[    43.986] (II) The server relies on udev to provide the list of input devices.
        If no devices become available, reconfigure udev or disable AutoAddDevices.
[    43.986] (II) Loader magic: 0x624c30
[    43.986] (II) Module ABI versions:
[    43.986]    X.Org ANSI C Emulation: 0.4
[    43.986]    X.Org Video Driver: 24.1
[    43.986]    X.Org XInput driver : 24.1
[    43.986]    X.Org Server Extension : 10.0
[    43.987] (II) xfree86: Adding drm device (/dev/dri/card0)
[    43.989] (II) no primary bus or device found
[    43.989]    falling back to /sys/devices/platform/display-subsystem/drm/card0
[    43.989] (II) LoadModule: "glx"
[    43.994] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[    44.005] (II) Module glx: vendor="X.Org Foundation"
[    44.005]    compiled for 1.20.13, module version = 1.0.0
[    44.005]    ABI class: X.Org Server Extension, version 10.0
[    44.005] (==) Matched modesetting as autoconfigured driver 0
[    44.005] (==) Matched fbdev as autoconfigured driver 1
[    44.005] (==) Assigned the driver to the xf86ConfigLayout
[    44.005] (II) LoadModule: "modesetting"
[    44.007] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
[    44.015] (II) Module modesetting: vendor="X.Org Foundation"
[    44.015]    compiled for 1.20.13, module version = 1.20.13
[    44.015]    Module class: X.Org Video Driver
[    44.016]    ABI class: X.Org Video Driver, version 24.1
[    44.016] (II) LoadModule: "fbdev"
[    44.016] (II) Loading /usr/lib64/xorg/modules/drivers/fbdev_drv.so
[    44.019] (II) Module fbdev: vendor="X.Org Foundation"
[    44.019]    compiled for 1.20.9, module version = 0.5.0
[    44.019]    Module class: X.Org Video Driver
[    44.019]    ABI class: X.Org Video Driver, version 24.1
[    44.019] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    44.019] (II) FBDEV: driver for framebuffer: fbdev
[    44.019] (++) using VT number 7
[    44.024] (II) modeset(0): using drv /dev/dri/card0
[    44.024] (WW) Falling back to old probe method for fbdev
[    44.024] (II) Loading sub module "fbdevhw"
[    44.024] (II) LoadModule: "fbdevhw"
[    44.027] (II) Loading /usr/lib64/xorg/modules/libfbdevhw.so
[    44.028] (II) Module fbdevhw: vendor="X.Org Foundation"
[    44.029]    compiled for 1.20.13, module version = 0.0.2
[    44.029]    ABI class: X.Org Video Driver, version 24.1
[    44.029] (EE) open /dev/fb0: No such file or directory
[    44.029] (II) modeset(0): Creating default Display subsection in Screen section
        "Default Screen Section" for depth/fbbpp 24/32
[    44.030] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[    44.030] (==) modeset(0): RGB weight 888
[    44.030] (==) modeset(0): Default visual is TrueColor
[    44.030] (II) Loading sub module "glamoregl"
[    44.030] (II) LoadModule: "glamoregl"
[    44.031] (II) Loading /usr/lib64/xorg/modules/libglamoregl.so
[    44.076] (II) Module glamoregl: vendor="X.Org Foundation"
[    44.076]    compiled for 1.20.13, module version = 1.0.1
[    44.076]    ABI class: X.Org ANSI C Emulation, version 0.4
[    46.636] (II) modeset(0): Refusing to try glamor on llvmpipe
[    46.643] (EE) modeset(0): glamor initialization failed
[    46.643] (II) modeset(0): ShadowFB: preferred NO, enabled NO
[    46.643] (II) modeset(0): Output HDMI-1 has no monitor section
[    46.644] (II) modeset(0): EDID for output HDMI-1
[    46.644] (II) modeset(0): Output HDMI-1 disconnected
[    46.644] (WW) modeset(0): No outputs definitely connected, trying again...
[    46.644] (WW) modeset(0): Unable to find connected outputs - setting 1024x768 initial framebuffer
[    46.644] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[    46.644] (==) modeset(0): DPI set to (96, 96)
[    46.644] (II) Loading sub module "fb"
[    46.644] (II) LoadModule: "fb"
[    46.645] (II) Loading /usr/lib64/xorg/modules/libfb.so
[    46.651] (II) Module fb: vendor="X.Org Foundation"
[    46.651]    compiled for 1.20.13, module version = 1.0.0
[    46.651]    ABI class: X.Org ANSI C Emulation, version 0.4
[    46.652] (II) UnloadModule: "fbdev"
[    46.652] (II) Unloading fbdev
[    46.652] (II) UnloadSubModule: "fbdevhw"
[    46.652] (II) Unloading fbdevhw
[    46.664] (==) modeset(0): Backing store enabled
[    46.664] (==) modeset(0): Silken mouse enabled
[    46.668] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[    46.669] (==) modeset(0): DPMS enabled
[    46.669] (II) Initializing extension Generic Event Extension
[    46.669] (II) Initializing extension SHAPE
[    46.669] (II) Initializing extension MIT-SHM
[    46.669] (II) Initializing extension XInputExtension
[    46.670] (II) Initializing extension XTEST
[    46.671] (II) Initializing extension BIG-REQUESTS
[    46.671] (II) Initializing extension SYNC
[    46.671] (II) Initializing extension XKEYBOARD
[    46.671] (II) Initializing extension XC-MISC
[    46.671] (II) Initializing extension XFIXES
[    46.671] (II) Initializing extension RENDER
[    46.671] (II) Initializing extension RANDR
[    46.671] (II) Initializing extension COMPOSITE
[    46.671] (II) Initializing extension DAMAGE
[    46.671] (II) Initializing extension MIT-SCREEN-SAVER
[    46.671] (II) Initializing extension DOUBLE-BUFFER
[    46.671] (II) Initializing extension RECORD
[    46.671] (II) Initializing extension DPMS
[    46.671] (II) Initializing extension Present
[    46.672] (II) Initializing extension DRI3
[    46.672] (II) Initializing extension X-Resource
[    46.672] (II) Initializing extension XVideo
[    46.672] (II) Initializing extension XVideo-MotionCompensation
[    46.672] (II) Initializing extension GLX
[    46.672] (II) AIGLX: Screen 0 is not DRI2 capable
[    46.832] (II) IGLX: Loaded and initialized swrast
[    46.832] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[    46.832] (II) Initializing extension XFree86-VidModeExtension
[    46.832] (II) Initializing extension XFree86-DGA
[    46.832] (II) Initializing extension XFree86-DRI
[    46.833] (II) Initializing extension DRI2
[    46.835] (II) modeset(0): Damage tracking initialized
[    47.584] (II) config/udev: Adding input device Logitech K400 Plus (/dev/input/event1)
[    47.584] (**) Logitech K400 Plus: Applying InputClass "evdev pointer catchall"
[    47.584] (**) Logitech K400 Plus: Applying InputClass "evdev keyboard catchall"
[    47.584] (**) Logitech K400 Plus: Applying InputClass "libinput pointer catchall"
[    47.584] (**) Logitech K400 Plus: Applying InputClass "libinput keyboard catchall"
[    47.584] (**) Logitech K400 Plus: Applying InputClass "keyboard-all"
[    47.584] (II) LoadModule: "libinput"
[    47.585] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[    47.609] (II) Module libinput: vendor="X.Org Foundation"
[    47.609]    compiled for 1.20.13, module version = 1.2.0
[    47.609]    Module class: X.Org XInput Driver
[    47.609]    ABI class: X.Org XInput driver, version 24.1
[    47.609] (II) Using input driver 'libinput' for 'Logitech K400 Plus'
[    47.609] (**) Logitech K400 Plus: always reports core events
[    47.609] (**) Option "Device" "/dev/input/event1"
[    47.611] (**) Option "_source" "server/udev"
[    47.646] (II) event1  - Logitech K400 Plus: is tagged by udev as: Keyboard Mouse
[    47.646] (II) event1  - Logitech K400 Plus: device is a pointer
[    47.646] (II) event1  - Logitech K400 Plus: device is a keyboard
[    47.647] (II) event1  - Logitech K400 Plus: device removed
[    47.681] (II) libinput: Logitech K400 Plus: needs a virtual subdevice
[    47.681] (**) Option "config_info" "udev:/sys/devices/platform/fd840000.usb/usb3/3-1/3-1:1.2/000"
[    47.681] (II) XINPUT: Adding extended input device "Logitech K400 Plus" (type: MOUSE, id 6)
[    47.682] (**) Option "AccelerationScheme" "none"
[    47.683] (**) Logitech K400 Plus: (accel) selected scheme none/0
[    47.683] (**) Logitech K400 Plus: (accel) acceleration factor: 2.000
[    47.683] (**) Logitech K400 Plus: (accel) acceleration threshold: 4
[    47.687] (II) event1  - Logitech K400 Plus: is tagged by udev as: Keyboard Mouse
[    47.687] (II) event1  - Logitech K400 Plus: device is a pointer
[    47.687] (II) event1  - Logitech K400 Plus: device is a keyboard
[    47.690] (II) config/udev: Adding input device Logitech K400 Plus (/dev/input/mouse0)
[    47.690] (II) No input driver specified, ignoring this device.
[    47.690] (II) This device may have been added with another device file.
[    47.692] (II) config/udev: Adding input device Analog RK817 Headphones (/dev/input/event0)
[    47.693] (II) No input driver specified, ignoring this device.
[    47.693] (II) This device may have been added with another device file.
[    47.722] (**) Logitech K400 Plus: Applying InputClass "evdev pointer catchall"
[    47.723] (**) Logitech K400 Plus: Applying InputClass "evdev keyboard catchall"
[    47.723] (**) Logitech K400 Plus: Applying InputClass "libinput pointer catchall"
[    47.723] (**) Logitech K400 Plus: Applying InputClass "libinput keyboard catchall"
[    47.723] (**) Logitech K400 Plus: Applying InputClass "keyboard-all"
[    47.723] (II) Using input driver 'libinput' for 'Logitech K400 Plus'
[    47.723] (**) Logitech K400 Plus: always reports core events
[    47.723] (**) Option "Device" "/dev/input/event1"
[    47.723] (**) Option "_source" "_driver/libinput"
[    47.723] (II) libinput: Logitech K400 Plus: is a virtual subdevice
[    47.724] (**) Option "config_info" "udev:/sys/devices/platform/fd840000.usb/usb3/3-1/3-1:1.2/000"
[    47.724] (II) XINPUT: Adding extended input device "Logitech K400 Plus" (type: KEYBOARD, id 7)
[    47.724] (**) Option "xkb_layout" "us"
[    47.724] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
after unplugging and replugging the HDMI cable:-
[   130.246] (II) modeset(0): EDID vendor "SNY", prod id 50179
[   130.247] (II) modeset(0): Using EDID range info for horizontal sync
[   130.247] (II) modeset(0): Using EDID range info for vertical refresh
[   130.247] (II) modeset(0): Printing DDC gathered Modelines:
[   130.247] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 )
[   130.247] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 )
[   130.248] (II) modeset(0): Modeline "1920x1080i"x0.0   74.25  1920 2008 2052 2200  1080 1084 1094)
[   130.248] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 )
[   130.248] (II) modeset(0): Modeline "1920x1080i"x0.0   74.25  1920 2448 2492 2640  1080 1084 1094)
[   130.248] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1720 1760 1980  720 725 730 750 )
[   130.248] (II) modeset(0): Modeline "1920x1080"x0.0   74.25  1920 2558 2602 2750  1080 1084 1089 )
[   130.248] (II) modeset(0): Modeline "1920x1080"x0.0   74.25  1920 2008 2052 2200  1080 1084 1089 )
[   130.248] (II) modeset(0): Modeline "1280x720"x0.0   59.40  1280 3040 3080 3300  720 725 730 750 )
[   130.248] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 3040 3080 3300  720 725 730 750 )
[   130.248] (II) modeset(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsyn)
[   130.248] (II) modeset(0): Modeline "1440x576i"x0.0   27.00  1440 1464 1590 1728  576 580 586 625)
[   130.248] (II) modeset(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsyn)
[   130.248] (II) modeset(0): Modeline "1440x480i"x0.0   27.00  1440 1478 1602 1716  480 488 494 525)
[   130.248] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsyn)
[   130.248] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsy)
[   130.248] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 )
[   130.248] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 )
[   130.249] (II) modeset(0): Modeline "1600x900"x60.0  119.00  1600 1696 1864 2128  900 901 904 932)
[   130.249] (II) modeset(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 )
[   130.249] (II) modeset(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 )
[   130.249] (--) modeset(0): HDMI max TMDS frequency 300000KHz
once the screen starts working it seems to continue working after a reboot
I even get some terminal stuff on the screen before X windows starts up.
In fact even if I do a halt, disconnect the power and then do a cold boot, the screen works.
I'm not getting a DHCP IP address from the eth0 though
(12-07-2021, 10:28 AM)dieselnutjob Wrote: I'm not getting a DHCP IP address from the eth0 though
I confirm until the reason is incomprehensible.
donation   irradium
update kernel 4.19.220
slarm64-current-aarch64-server-quartz64-4.19.220-build-20211208.img.zst
slarm64-current-aarch64-server-quartz64-4.19.220-build-20211208.img.zst.sha256
slarm64-current-aarch64-xfce-quartz64-4.19.220-build-20211208.img.zst
slarm64-current-aarch64-xfce-quartz64-4.19.220-build-20211208.img.zst.sha256
donation   irradium
mara, if I compile my own Kernel and want to drop it into your SLARM64 image, how would I create a new uInitrd file please?
(12-12-2021, 02:56 PM)dieselnutjob Wrote: mara, if I compile my own Kernel and want to drop it into your SLARM64 image, how would I create a new uInitrd file please?
for this there is /boot/rebuild-initrd.sh, boot with the new kernel and run the script.
or use the function from the assembly script.
donation   irradium
(12-09-2021, 05:27 AM)mara Wrote: update kernel 4.19.220
The above XFCE has broken link, here is the working link: http://dl.slarm64.org/slackware/images/q...08.img.zst
Hi Mara
If I compile and boot a kernel that I compiled myself, how do I populate /lib/modules/{version}?
currently I only have /lib/modules/{oldversion}
I can see all of the .ko files listed when the modules were compiled, but then there are all the other files like aliases
I am assuming that there is some normal way to do it that I don't know.
Until I have a /lib/modules I can't run rebuild-initrd.sh
(01-28-2022, 05:21 PM)dieselnutjob Wrote: Hi Mara
after compiling you did:
make O=$(pwd) ARCH=arm64 INSTALL_MOD_PATH=/lib/modules modules_install
donation   irradium
I am cross compiling on a normal PC.  Does that make a difference?
no, specify where to install the modules and then transfer to the sdcard
donation   irradium
  USB on Quartz64 Zero litbulb 1 1,971 07-22-2026, 02:04 PM
Last Post: MichaIng
  DietPi OS for Quartz64 MichaIng 48 58,208 07-22-2026, 01:52 PM
Last Post: MichaIng
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 8 18,053 03-07-2026, 04:21 PM
  How does CPU frequency scaling work on the Quartz64 pugzarecute 0 2,331 07-30-2025, 07:19 AM
Last Post: pugzarecute
  Armbian and LibreELEC and AltLinux for Quartz64 balbes150 152 179,760 03-23-2025, 01:10 AM
Last Post: balbes150
  quartz64-a - on-board SATA port problems manning 2 5,549 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 4,443 07-20-2023, 10:44 PM
Last Post: beepy
  crux-arm Quartz64 RK3566 (aarch64) mara 5 10,896 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 4,034 07-21-2022, 01:08 PM
Last Post: Randomuser
  Armbian on Quartz64 dieselnutjob 34 56,512 03-17-2022, 06:29 AM
