Armbian for Rock64
#31
(05-08-2021, 03:51 AM)Wizzard Wrote: Correct, it is Rockbox, with Rock64 chipset.
Assuming this is a Popcorn Hour RockBox, then from my quick research it has some of the rock64 chipset but it is not a rock64 (Ethernet speed slower and WiFi present), it is not a rock64 board in case.
My guess is that the hardware is too different
This is why I asked here, I guess somebody should have tried it too. I think we just have to find the correct DTB, maybe from some Libreelec build.
You mentioned Popcorn Hour and I am looking forward to build some kind of media centre similar to Popcorn Hour.
Instead of buying a Raspberry Pi I want to give Pine's Rock64 a try, but it seems finding out a well tested Linux distro or pre-compiled binaries is not as straigth forward as in the RPi world is. I assume this is a hardworkers' community and I want to support it.
Idea Can you provide me with good advice about buying a Rock64 or a Rock64PRO. I want to play video (mostly HD and some in HEVC but very rare) and transmit audio with a bluetooth adapter.
Thanks.
You could try Android. Once installed you can use the many media apps available out there. Android 9 rooted works very well on the Rock64. Just a suggestion.
By Android 9 rooted you mean the same distro/flavor of Google's Android or some kind of "Degoogleized" version?
(10-21-2021, 02:15 PM)arle Wrote: By Android 9 rooted you mean the same distro/flavor of Google's Android or some kind of "Degoogleized" version?
Rooted. Full access to all aspects of the OS. No Google Play Store either. Use ADB to install your Apps. Much better setup too.
(10-16-2021, 01:40 PM)Rocklobster Wrote: You could try Android. Once installed you can use the many media apps available out there. Android 9 rooted works very well on the Rock64. Just a suggestion.
Do you have some link to working Android for RockBox? I installed Linux but I prefer to go back to stock Android.
hello I have installed rock64 armbian debian bullseye, on the emmc card and I have an ssd disk by usb3, the disk is mounted in /etc/fstab, but every day approx it gives me an error
blk_update_request: critical target error, dev sda, sector 250069504 op 0x0SadREAD) flags 0x0 phys_seg 1 prio class 0
[18241.624593] Buffer I/O error on dev sda, logical block 31258688, async page read
I have tried several discs and it happens to all of them
Is there something to be able to install so that I don't get that error
Thanks a lot
(01-18-2022, 12:57 PM)gedas07 Wrote: hello I have installed rock64 armbian debian bullseye, on the emmc card and I have an ssd disk by usb3, the disk is mounted in /etc/fstab, but every day approx it gives me an error
Thanks a lot
Do you have another computer you could use to check the integrity of your SSD drives. Possibly a faulty batch. Alternatively could you install the Armbian Buster distribution and try that. Bullseye is known to be quite buggy at the moment.
Thanks a lot
Thanks for your answer
But the ssd, it worked perfectly, a day before with ubuntu 18, but with bullseye it gives those I/O failures
I have put another different ssd and after a few days it gives the same error
  rAudio for Rock64 V2/Pine A64+ shinzuka 11 1,649 Yesterday, 03:16 PM
Last Post: shinzuka
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 12 18,579 03-07-2026, 11:04 AM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,073 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 5,950 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 11,842 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,185 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,366 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,361 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 86,325 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 110,151 09-01-2024, 06:05 AM
