Can't get autofocus working
I'm running into difficulty getting main camera autofocus running.  I've taken the following steps:
  1. Replaced my Braveheart motherboard with a new 3GiB motherboard.
  2. Replaced my camera module with a new one.
  3. Installed the latest Mobian weekly (2022-01-02).
  4. Upgraded all the things ( sudo apt-get upgrade -y ).
  5. Started Megapixels, and tapped the screen to trigger autofocus.
At this point the focus jumps around a bit (looks like autofocus starting to work as it does on other devices), but it never manages to properly focus on anything more than a few centimeters from the lens.  During this, the following is logged in dmesg:
[ 7895.103889] ov5640 3-004c: uploaded firmware didn't start, got to 0x7f, retrying...
[ 7895.423877] ov5640 3-004c: uploaded firmware didn't start, got to 0x7f
[ 7895.430507] ov5640 3-004c: ov5640_set_ctrl_focus: no autofocus firmware loaded
[ 7899.123759] ov5640 3-004c: firmware upload success
[ 7899.129210] ov5640 3-004c: fw started after 0 ms
The camera works just fine when I "focus" it by physically moving it close to an object:
[Image: IMG20220108060633.jpg]
... but if I try to take a photo of anything more than a few centimeters away, it completely fails to focus:
[Image: IMG20220108060559.jpg]
Any help would be greatly appreciated, as this is the final hurdle for me to adopt a PinePhone as my daily driver Smile
An update: I still can't get this to work.  I've tried every firmware at https://github.com/dragan-simic/ov5640-a...-firmware/, and also tried recompiling Megapixels from the latest source.
The basic behaviour is still the same: dmesg reports success; camera clicks indicating the lens is being controlled by the AF, and the focus jumps about when I touch the screen in Megapixels.  But it still seems completely unable to actually focus properly.
Sounds strange, especially since you already changed the hardware. Have you made sure your lens and the cover from the case is clean? Maybe there is some dust or something that prevents the auto focus from working correctly. You could take off the back case of the phone and see if it behaves differently.
I believe the lens is not working properly, Try adding back-inn.
So I solved it with a pair of tweezers Smile  Steps were ...
1. Remove the back cover.
2. Remove the inner back cover by taking out the screws.
3. Fine-tune the lens position by rotating it in the barrel with a pair of tweezers, while manually checking the results in Megapixels.
End result:
[Image: IMG20220123140940.jpg]
  4G VoLTE calls confirmed working with carrier x dcinoz 17 39,474 10-07-2025, 11:05 AM
Last Post: baptx
  MMS sending stopped working amindfv 7 8,283 05-04-2025, 01:36 PM
Last Post: zetabeta
  My new phone stopped working. gunnygee 3 4,924 12-12-2024, 01:21 PM
  Instructions to get pinephone working on USA carrier omarcomputing 1 4,434 10-08-2022, 04:45 PM
Last Post: treebeard
  JumpDrive isn't working phytocube 2 5,111 06-05-2022, 03:22 PM
Last Post: phytocube
  SIM card slot not working dekrets 2 5,159 02-12-2022, 11:09 AM
Last Post: dekrets
  PinePhone Beta 3GB modem not working hannescam 15 20,004 01-19-2022, 02:08 AM
Last Post: bcnaz
  Video Out not working BenniTec 7 11,159 10-21-2021, 11:56 AM
Last Post: BenniTec
  How did you get data working on PureTalk? nelstomlinson 2 6,876 09-26-2021, 03:50 PM
Last Post: nelstomlinson
  JumpDrive not working due to device busy cnxsoft 3 6,373 08-08-2021, 12:18 AM
Last Post: mouffa
