wifi adapter not found.. why?
Hi.. Why is my wifi adapter not found?
You did not give any details ?
but, If your wifi is 'turned-off' it will say 'no wifi found'.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
When this happened to me I found that I had accidentally touched the WiFi icon in the top drop-down menu and turned it off.
@b7l3wui26r make sure airplane mode is disabled (you should see it in wifi settings). If nothing helps try restarting the phone. It's probably not the most practical solution, but it works for me when I have wifi issues.
  OpenTTD game - Error: no usable screen resolutions found. eugenr 3 6,073 06-23-2026, 01:12 AM
Last Post: Mary_Davis
  reset wifi hardware/driver when it dies through console on pp? tuxcall 5 6,817 03-10-2026, 04:43 PM
Last Post: baptx
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 7,511 02-20-2025, 02:47 PM
Last Post: puffchumpy
  Wifi doesn't work after update nickolas 2 4,588 04-14-2023, 10:07 AM
Last Post: nickolas
  Boot log analyses -> GPU no regulator (mali) found freelectro 0 2,803 03-06-2023, 12:06 PM
Last Post: freelectro
  Recent install, no wifi user641 3 4,791 01-12-2023, 03:06 PM
Last Post: user641
Exclamation No modems were found: No mobile data, no 2G anonymous 2 4,700 12-26-2022, 06:46 PM
Last Post: anonymous
  Wifi issue since last update and held back updates goku499 11 15,165 09-21-2022, 02:39 PM
Last Post: Katsujinken
  Problem with wifi kubussz 0 2,075 04-02-2022, 12:57 PM
Last Post: kubussz
  Wi-Fi adapter suddenly gone missing Zebulon Walton 1 3,403 11-15-2021, 05:20 PM
