Axolotl on PinePhone / Mobian
(11-17-2021, 10:02 AM)ragreenburg Wrote: I am on Axolotl 1.0.7 and I am unable to receive messages but I seem to be able to send them just fine, started about a week ago. Anyone else having this issue?
Hello there,
sadly, that's the current state of Axolotl. But nanu-c and jonnius are working on the issue as fast as they can. A bit more time is needed but it's looking quite good.
When v1.0.8 with the fix is out, I will post it here.
Cheers!
Question
I can still send and recieve Smile , and Axolotl looks much nicer now sice latest update Smile ... but since the Axolotl update I can no longer type emojis and no "o" or "z". Huh
This only happens in Axolotl, and I can still type those symbols/chars in other applications an copy&paste them into Axolotl. Very strange. Am I the only one?
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
(11-17-2021, 02:14 PM)dante404 Wrote: I can still send and recieve Smile , and Axolotl looks much nicer now sice latest update Smile ... but since the Axolotl update I can no longer type emojis and no "o" or "z". Huh
That's indeed new since the latest Electron update - Could you post an issue here with some details? That would be great!
https://github.com/nanu-c/axolotl/issues
Thanks a lot!
Here is the bug report
https://github.com/nanu-c/axolotl/issues/635
Here you can find an arm64 package of Axolotl for Mobian or other Debian-based distros in version 1.0.8.
This version of Axolotl was cross-compiled from scratch using the repository Makefile and has the following main improvements:
  • Support receiving unidentfied sender messages -> fixes receiving messages
  • French translation updated
  • Delete warning message
  • Standardise gettext usage
  • Update electron (REVOKED ON MOBIAN DUE TO ELECTRON-WAYLAND BUG)
  • Cross-compile capabilities in the makefile
  • Debian packaging improvements
https://github.com/nuehm-arno/axolotl-mobian-package
Cheers!
(11-17-2021, 03:02 PM)arno_nuehm Wrote: That's indeed new since the latest Electron update - Could you post an issue here with some details? That would be great!
Sorry for not posting the bug report myself  Sad - I'm only checking the pine64 forum 1-2 times a week...
(11-23-2021, 02:43 AM)arno_nuehm Wrote: Here you can find an arm64 package of Axolotl for Mobian or other Debian-based distros in version 1.0.8.
Thank you, thank you, thank you, guys!
However, I cannot link Axolotl to the Signal Desktop App (which was not problem in the past). Entering the code and pressing add in Settings/Linked Devices in Axolotl does not produce any change in the Signal App.
But it's great to be able to use Signal on the Pinephone again!
You are very welcome!
Signal changed the import string of the QR-code for Signal Desktop. Do you run Signal Desktop in the latest version? If not, please try an update, because the old "tsdevice..." string is not working anymore. It should start with "sgnl...".
(11-24-2021, 11:48 AM)arno_nuehm Wrote: Do you run Signal Desktop in the latest version? If not, please try an update, because the old "tsdevice..." string is not working anymore. It should start with "sgnl...".
That fixed it, thank you!
I'm really happy that everything is working again. Axolotol is really crucial, somewhere at the top of my personal list of indispensable apps.
Axolotl stopped sending / receiving messages two days ago (Deskotp App still works).
In anybody else experiencing problems?
EDIT: Just started Axolotl now and all at once received several messages I had received and written (in the Deskop app) over the past tow days -- but not all of the. In one chat, I only got the messages till 20 hours ago, in another chat, I only receive the messages that I write (again: in the desktop app) but not the replies.
Very strange.
EDIT 2: Restarted Axolotl again and received even more of the missing messages. Remains erratic though, in one chat for example I only got the messages I had received, not the ones I had sent.
  Mobian MMS/SMS text problem bcnaz 16 39,280 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,772 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 68,779 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 73,604 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,401 06-29-2025, 12:38 PM
Last Post: Hiraghm
  VoIP account on mobian dialer j_s 0 3,072 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,251 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 5,002 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 4,700 04-29-2025, 02:10 PM
Last Post: mdk
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 7,928 02-20-2025, 02:47 PM
Last Post: puffchumpy
