Help with bypassing Arch check in Pamac
Hi guys
I am trying to install printer drivers on my Pinebook Pro but unfortunately thee driver I have found on the AUR is not available for the ARM architecture.
I have done some digging and found this Reddit thread:
https://www.reddit.com/r/archlinux/comme...t_for_aur/
One of the comments here say you can bypass the architecture check in pacman by using the -A command and there is still a chance that it will work and I am willing to test it.
Unfortunately I am not currently at the level of being able to use pacman to install something from the AUR so I was wondering whether there was a way to bypass the architecture check on pamac instead?
Kind regards
Josh
Err--No
Yes you can force the install, it likely won't work unless you, by luck, pick the right settings
ppd's are stored in /etc/cups/ppd
this is about line 10,,, *cupsFilter: "application/vnd.cups-postscript 0 brother_lpdwrapper_mfcj825dw"
The bit after the "0" is a "filter driver", it is a x86 binary and of course will not work on arm
What you want is "driverless" or ipp_everywhere" which are almost identical
These talk to a printer ON THE NETWORK and use a driver INSIDE the printer
You can do it over usb, but you have to set up a network driver for it, a little difficult
(note,, if printer has no network capabilities it probably does not have driverless in its rom)
a line from a driverless printer's ppd.... NickName: "Brother MFC-J6510DW, driverless, cups-filters 1.27.5"
Install cups, go to localhost:631 (in browser) , login as root, add printer (best over ipp)
do NOT pick a specific printer model, pick driverless or ipp_everywhere
Sometimes you have to do it 2 or 3 times before you get it right, if the test page is ok then it is right
Delete the ones not working
---another edit,
you have to set up the printer to be connected to your network for this to work,
from the printers' menus or cups won't find it (unless it is ethernet which connects more or less automatically if you tell printer to use it)
The person above probably gave the answer you needed, but not the one you asked for.
To ignore arch while building a package, you can run makepkg -A not pacman -A as pacman doesn't integrate the aur.
Many AUR helpers integrate this functionality already such a paru, which will prompt you to "build the package anyway" if the arch does not match yours.
For pamac I do not know, though you can use pamac to install paru (which I mentioned above) though this is a cli application.
To use paru simply type paru package_name in a terminal, the rest is intuitive.
You can also build the package manually by using
git clone https://aur.archlinux.org/package_name.git
cd package_name
makepkg -A
And then install it by using
pacman -U package_name.tar.xz
  By the way, yay arch... KC9UDX 4 5,865 03-30-2024, 10:27 PM
  PineBook HOW TO REINSTALL ARCH-Manjaro. Ice-O-Star 0 2,608 10-22-2022, 10:46 AM
Last Post: Ice-O-Star
  Arch Linux ARM root filesystem SKiljan 24 46,227 09-24-2022, 03:11 AM
Last Post: alexandre
  Booting Arch from USB lorebett 6 8,920 09-18-2022, 11:35 AM
Last Post: lorebett
  Manjaro Gnome 22.06 pamac update fail/soft-bricked-OS u974615 5 7,498 08-21-2022, 12:00 PM
Last Post: u974615
  Manjaro and Arch repository with privacy oriented software as400 86 213,813 04-27-2022, 07:44 AM
Last Post: annahellrothsparent
  Downloading Spyder causes Pamac to freeze mjc 4 10,280 09-27-2020, 10:11 AM
Last Post: mjc
  Arch ARM iso for Pinebook Pro hanmorten 2 6,805 07-09-2020, 01:37 AM
Last Post: hanmorten
  boots not after try installing arch definitiv. 3 9,295 06-17-2020, 04:06 PM
Last Post: definitiv.
  Cant boot into home-rolled Arch Linux image craftkiller 4 8,606 02-25-2020, 12:58 PM
Last Post: craftkiller
