TV64, a Android TV Experince 0.2
I received my Pine64 yesterday, and first thing I did was to install your image. I was almost shocked to see that it worked right away with no problems - I am not used to that...
Now I am trying to find a way to control the Pine from my phone. I don't want to have a keyboard and mouse attached. Any suggestions? I have tried TeamViewer and RemoDroid, but I haven't had any success.
There's a android tv remote app for android. But it does not recognize this image as android tv.
Sent from my Nexus 6 using Tapatalk
Phoenix refuses to burn this ("Script not found! Please use new version image."), and since it's an 8GB image it appears there's no way to expand this to fill my larger (32GB) card.  Am I missing something? Is there some way to bully Phoenix into burning it (or alternatively expand the partition once it's loaded)?
Afaik this is not a Phoenix image. Use Rufus to put it on your sd card!
beire is correct - this is a dd image
(05-25-2016, 05:20 AM)Luke Wrote: beire is correct - this is a dd image
So there's no way to utilize a larger card? I really want to try this, but that would be a non-starter for me.
Will test it out now - get back to you when Im done (will update this post). [edit] If this works then I will make a tutorial - so it may take a couple of hrs. Will post a link to the tutorial here if I will succeed.
(05-24-2016, 12:23 PM)trondis23 Wrote: I received my Pine64 yesterday, and first thing I did was to install your image. I was almost shocked to see that it worked right away with no problems - I am not used to that...
I've been using DroidMote but you need to be rooted to use it, not sure if this img is rooted or rootable. I'm using it with no problems on Release 20160505. Install the server app on the Pine and install the client app on your phone or tablet. Client app does not need root. I'm using it from my unrooted Galaxy S6 to control my Pine.
#19
gtpboy: the image is rooted
#20
(05-25-2016, 08:21 AM)Luke Wrote: gtpboy: the image is rooted
Well then DroidMote should work perfectly. I think it's like $3.34 for the Server App but it works flawlessly.
  Need help compiling android for pine a64 + YeeticusMaximus22 2 2,772 08-20-2026, 08:45 AM
Last Post: ahegarosib97
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 612,918 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 50,585 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 32,239 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,803 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 14,396 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,674 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,825 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 411,460 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 7,607 02-26-2019, 11:58 AM
Last Post: Twistedx
