Pinephone bricked after connecting to a PC over USB
Hi all, I was hoping someone here might be able to help me. My Pinephone seems to be bricked ever since I connected it to my PC.
This happened while I was trying to burn the new Manjaro Beta 17 to the eMMC. I inserted an SD card with JumpDrive (I'm not sure which version, but it is pretty old, from ~6 months ago, if that matters) and turned on the phone. I was greeted with the familiar JumpDrive screen. I then plugged in the USB A/C into the Pinephone and my Linux computer and nothing happened - I didn't see any new drives in the file manager or GParted. I tried other USB ports on my computer, but none of them worked.
I then tried the same thing with a different computer, running Windows 10. The first two USB ports I tried produced the same result. The third one worked - or so I thought. Windows went into a loop of detecting the drive and disconnecting it (I guess). This connect/disconnect behavior was happening around once every second. After a few seconds I disconnected the Pinephone and ever since then it won't boot. The screen is totally black no matter what I do. I tried turning it on with and without the SD card (since I have an older Manjaro installed on the eMMC) by holding the power button for 4+ seconds. I tried putting the phone on the charger in case the battery discharged in the meantime, but that didn't help either.
Does anyone have a suggestion on what I could try? Thanks in advance.
I had sometimes experienced the not connecting at all/constantly connecting and disconnecting as well (on Linux). It always worked again after a couple of tries or reboots, no idea what the cause was. I blamed it on the phone's USB port, but just because it seemed the most likely.
Anyway, have you tried another OS on the SD card? There is also a Jumpdrive version specifically for very low battery that you could try in case your battery has in fact drained too much (the one with the -charging suffix).
Bug PinePhone modem keeps "disappearing" Kevin Kofler 21 22,677 09-11-2026, 09:18 AM
Last Post: idice
  Pinephone + Keyboard for sale, little use ruemoo 18 14,914 08-23-2026, 12:17 AM
Last Post: Nambo
  Pinephone - broken power button rorus 14 25,590 05-17-2026, 03:52 PM
Last Post: EuvzO8
  PinePhone 16 GB – Free to a Good Home Anna 2 2,332 01-20-2026, 01:43 PM
Last Post: Anna
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 4 8,725 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 4,173 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 3,282 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 6,797 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 4,988 06-21-2025, 05:19 PM
Last Post: mikeb
  Pinephone not booting sd card... bruv 1 3,683 03-25-2025, 08:51 PM
