Android Ethernet Problem
Hello everyone, I have some difficulty using Android.
Every time I open my browser(Chorme), it says that I don't connect the Internet.
Then I installed "Android Terminal Emulator" to check whether the ethernet is working well.
But every time on boot, "ifconfig eth0" tells me that it couldn't assign ...
When I use su command to assign a specific IP address to it, it works.
But, what I can do then is only being able to ping through my router, I still can't connect the Internet.
I've also tried on ather OSs like Remix and Ubuntu, but both of them CAN connect the Internet.
Maybe is there anything wrong with the Android system or are there any settings I forget to set?
(05-20-2016, 03:52 AM)a5467021 Wrote: Hello everyone, I have some difficulty using Android.
This is strange, the Remix and Android using same boot image and should have same result. From your description, seems like not getting IP assigned. But why your router to assign IP to Android build, I have no idea. Try to unplug and plug again the ethernet cable after Android build already boot up and check again whether IP can be assigned. The easier way to know is checking the clock status. If this method work, this means your router somehow not able to assigned IP to Android build during boot up.
Excuse me, I don't know what "clock status" means...
I've tried to unplug and plug it again, but it didn't seems to work, and restarting the router is useless as well.
I noticed that the green LED on the ethernet socket is always on, but the yellow one seldom twinkles.
Maybe I forget to say that Remix OS also have some problem at the beginning. I assigned a specific IP to it and it didn't work either. But after I set the DNS server, it was able to connect the Internet. Maybe I also have to set DNS server in Android, but where can I set it?
If Android and Remix have same issue, then my assumption may not be correct.
But the problem of Remix was finally solved, so I think there should also be a method for Android?
This is the part that puzzle us. Frankly speaking, the Ethernet driver on Android and Remix builds are identical.
(05-20-2016, 10:37 AM)tllim Wrote: This is strange, the Remix and Android using same boot image and should have same result. From your description, seems like not getting IP assigned. But why your router to assign IP to Android build, I have no idea. Try to unplug and plug again the ethernet cable after Android build already boot up and check again whether IP can be assigned. The easier way to know is checking the clock status. If this method work, this means your router somehow not able to assigned IP to Android build during boot up.
Yeah, so I think there should also be an effective way setting DNS for Android. Do you have some idea or can you recommend some useful tools about it?
(05-20-2016, 11:37 PM)a5467021 Wrote: Excuse me, I don't know what "clock status" means...
I scratch my head, no new idea.
(05-21-2016, 08:24 AM)tllim Wrote: If Android and Remix have same issue, then my assumption may not be correct.
That's a pity. But I just don't wanna give it up, so if there's any progress made, please tell me as soon as possible Smile
I have the 2GB+ board and Ethernet doesn't work on Android or RemixOS. I was told that the GigE card has issues. It does work with Debian, if you give that a shot.
  Need help compiling android for pine a64 + YeeticusMaximus22 2 2,423 08-20-2026, 08:45 AM
Last Post: ahegarosib97
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 604,007 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 49,845 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 31,774 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,562 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 14,102 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,474 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,665 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 406,898 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 7,420 02-26-2019, 11:58 AM
Last Post: Twistedx
