New Pine Phone User In Canada
(10-05-2021, 09:18 AM)Zebulon Walton Wrote: A wired headset will work with Mobian but what you have to do is first dial the call then plug the headset into the jack. Kind of goofy but hopefully that will be remedied at some point.
I've never been able to get bluetooth audio working. My Samsung bluetooth headset, which worked perfectly fine with my old flip phone, just spits out static when connected to the Pinephone.
*nod* I see I see, very interesting. I'll give that a try but I was hoping to get it to work while watching YouTube or listening to MP3s. It continues to play audio on the Pine Phone's speaker even when headphones are then plugged into the jack. I looked to see if there was an option in the settings to toggle output to the headphone jack but didn't see an option for it. So we may just have to wait for support to be added in a future revision.
OK, I misunderstood. I really have not been using my Pinephone for anything other than phone calls.
Just for grins I plugged in a set of stereo earbuds and checked Settings/Sound. It automatically shows the output device as "Headset". I then played an mp3 audio file and it does play through the earbuds. Ditto for playing mp4 video. I'm running Mobian Bookworm with updates as of a couple of days ago, using VLC media player for both audio and video files.
(10-02-2021, 02:41 PM)bcnaz Wrote: @tllim
Above,  I was referring to a home computer operating system.
Though I did talk to one of the Zorin brothers about the Pinephone last year.
They were working on adding the arm/pi software as their first arm supported O.S.
At that time they had their hands full,  but he did say they 'may consider supporting the Pinephone in the future'  ...
Thanks on approaching Zorin and glad to know they are considering :-)
(10-05-2021, 11:59 AM)Zebulon Walton Wrote: OK, I misunderstood. I really have not been using my Pinephone for anything other than phone calls.
I was wrong. The headphone jack does work. I tried a different pair and it was fine. It may not have liked the initial set because they're the kind which have a dongle for playback controls.
Better late than never I hope.
I’m on bullseye and you can change the audio output in settings → Sound menu.
A great headset works really nice for odysee/youtube. JBL bluetooth speakers work fine, but if you want to go to full volume on the speakers, you need to use the volume control buttons on the speaker itself.  Max out the volume on the phone first and then adjust it on the speakers, mine can get really loud.
I’m using vlc for audio & video files & haven’t got into lollypop yet; in a heavy work cycle for about 3 more weeks, so my free time is way down.
PinePhone, Pinebook Pro & PineTab2 owner.
  Default password for KDE plasma pine phone Toni 0 8,504 09-14-2025, 06:35 PM
Last Post: Toni
  Public Mobile (Canada): failure to configure VoLTE digdis 6 5,632 07-14-2025, 04:17 PM
Last Post: digdis
  My new phone stopped working. gunnygee 3 4,949 12-12-2024, 01:21 PM
  Pine Phone in Australaa and Telstra tracyanne 2 3,430 12-06-2024, 02:42 AM
Last Post: tracyanne
  Can't complete update of manjaro: wwan0 stays disabled; no phone/text gilford 3 4,536 12-05-2024, 06:42 AM
Last Post: gilford
  2G, 3G still is in phone. Piotr Bujakowski 5 6,983 09-19-2024, 03:49 AM
Last Post: jennybaso
  Looking for the "non-phone" OS wakyct 7 9,406 03-14-2024, 03:51 AM
Last Post: MTXP
  Writing apps/programs for pine phone katesfb 7 13,199 03-11-2024, 10:42 PM
Last Post: Emelia525
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 4,875 01-09-2024, 07:02 PM
Last Post: britelite
  Pine company idea aular 9 9,577 12-07-2023, 12:32 AM
