Power button: Holes filled in?
I was trying to attach my power button but I noticed the holes where you are supposed to put the power button in were filled. I tried soldering the button on the side, where 2 pins on top of the board reach their desired area, and the other 2 pins reach their desired area on the bottom of the board; how however, it does not work. I have seen pictures of what I think it is supposed to look like, but that was not possible with my board. Thanks!
(05-23-2016, 09:52 AM)joshdude58 Wrote: I was trying to attach my power button but I noticed the holes where you are supposed to put the power button in were filled. I tried soldering the button on the side, where 2 pins on top of the board reach their desired area, and the other 2 pins reach their desired area on the bottom of the board; how however, it does not work. I have seen pictures of what I think it is supposed to look like, but that was not possible with my board. Thanks!
Hi. Can you post some photos of your board (with a focus on the power button area), please?
Sounds like the holes are filled in with solder- try melting them hole by hole and slowly lowering all four connections in by remelting and pushing further in.
My pine had the same condition.
If I've helped you with something, please leave a rating for my responses.
  New RockPro64 Power Up Problem enorbet2 7 14,402 10-28-2023, 12:08 PM
Last Post: dkebler
  Pinecil power Erincka 0 3,610 03-21-2021, 11:52 AM
Last Post: Erincka
  Session fails to fully start after unexpected power off during initial upgrade Avron 0 3,698 03-18-2021, 11:52 AM
Last Post: Avron
  Power button sdziuba 1 4,593 03-14-2021, 09:05 AM
Last Post: xalius
  PBP won't power. Charge light solid orange/red but turns off. cmicallef 15 25,133 03-12-2021, 07:08 PM
Last Post: cmicallef
  howto power hdd via usb3 on rockpro64 hanscees 2 8,649 06-17-2020, 02:00 AM
Last Post: hanscees
  User Screen Black After Changing Power Settings 0b51Gekko 2 8,214 07-03-2019, 07:53 AM
Last Post: 0b51Gekko
  5.25 V _ ... 2A Power USB Adapter Guest2000 4 12,276 02-12-2017, 09:34 PM
  Power Switch for Pine64 512MB Board MonarchOfLight 0 4,187 10-24-2016, 04:33 PM
Last Post: MonarchOfLight
  Power Ribbon for LCD Display Plot 3 9,854 10-23-2016, 12:16 PM
Last Post: dkryder
