What will you be using your PINE64 for?
#61
A BBQ prob base. 8 probes and eventually several remote probes and draft controllers. With cloud database and UI.
#62
I'll probably look it for a long while as I have no idea how to get it going. But that does not mean I won't learn with the help of someone.
I bought a 1 GB (I think) with b/t w/f and Z wave All in the acrylic case. My aim was to get Z wave going but again I am not sure where to start.
If someone would like to give an absolute beginner some starting tips I would really appreciate it.
Mick
#63
After playing with the Linux distro and checking performance of the audio I/O ports, I'm going to try and get some bare metal code loading on the thing, then possibly start a port of FreeRTOS to the board. That could be quite the cool thing!
#64
I'm using one of my pines as a pine64 community IRC server (in sig). The other is reserved for experimenting. So far I have tried all the different Linux distros - I'm currently on Debian - and RemixOS. I am still to try the Android img. I may just end up setting my second Pine64 up as a web server and torrent box (to help out my fav distros / Pine64 imgs).
#65
My first goal will be connecting it to a MIDI sprout
https://www.kickstarter.com/projects/dat...ion-device
and record MIDI.
#66
Using it as a paper weight.
#67
(05-23-2016, 08:52 AM)fneves Wrote: Using it as a paper weight.
Please send a picture.
#68
what issue(s) are you experiencing ?
#69
I'm hoping to be able to use them for PCAP. Currently we use micro Ubuntu PC's. I have a few other things in mind, but I'm hoping they have enough grunt to pull this off.
I'm also planning to use one for a desktop if it gets enough performance. I rarely use my gaming PC for gaming anymore.. Figure it's a bit of a power sink for what little web surfing I do. RemixOS should give me everything I need in that respect.
#70
I have 4 spare 1U cases, I bought a temperature sensor board to control the fans and will mount my 6 1GB boards in there, with a 16 port gigabit router and with room for 9 more Pine64 later. I will then put a minimal Linux OS on my boards. Then add a Python 2.7 environment. That is all I need to then distribute my Machine Learning routines across all 6 boards supporting ensemble learning. If successful I'll expand to 15 boards, giving me 60 cores to play with. A GPU might be more powerful for the matrix manipulations, but involves extra code and more heat.
Question External storage problem for pine64 Dani6102 3 7,107 07-26-2023, 10:57 AM
  Pine64 as wireless audio device S265 3 9,256 04-07-2022, 10:39 PM
Last Post: S265
  Pine64(+) and manjaro dsychan 0 4,564 04-05-2022, 11:32 PM
Last Post: dsychan
Thumbs Down Pine64 was a Useless Project pushpendrak 18 44,658 11-21-2020, 10:17 PM
  Pine64 LCD rstcologne 0 5,645 09-22-2020, 12:43 PM
Last Post: rstcologne
  Pine64+ power button PaddyChan 0 5,508 09-14-2020, 09:55 AM
Last Post: PaddyChan
  Pine64 OS dpcons 2 7,823 03-02-2020, 04:32 PM
Last Post: dpcons
  Jailhouse supports Pine64+ vj-kumar 0 5,885 02-17-2020, 11:39 PM
Last Post: vj-kumar
  PINE64 board not powering up loki21century 2 9,030 11-25-2019, 12:19 PM
Last Post: Partymack711
  Pine64 not powering up. skylab 5 12,883 05-03-2019, 02:48 PM
Last Post: Mendota
