how to make a terminal command run as an icon in arch-phosh
I have an application (blender) that only runs with
LIBGL_ALWAYS_SOFTWARE=1 blender
how can I make it so I can use a blender icon in the phone's home menu to run the above command
Does Blender already have an icon in the launcher? If so, you will probably find the corresponding .desktop file in /usr/share/applications/. In that file insert setting the variable on the "Exec=" line:
Exec=env LIBGL_ALWAYS_SOFTWARE=1 blender
If you want to keep this file from being overwritten (e. g. with package updates), you can copy the .desktop file to ~/.local/share/applications/ which will take precedence over the one in /usr/share/applications.
If no .desktop file for blender exists, you have to create a new one.
(09-24-2021, 06:57 PM)kqlnut Wrote: Does Blender already have an icon in the launcher? If so, you will probably find the corresponding .desktop file in /usr/share/applications/. In that file insert setting the variable on the "Exec=" line:
OR:
Create a 1-line script with your code, make it executable and name something like "blender-code" and place in /usr/local/bin;
Then create your own launcher called "blender.desktop" in ~/.local/share/share/applications with the following lines:
    [Desktop Entry]
   Name=Blender
   Type=Application
   Exec=/usr/local/bin/blender-code
   Categories=Utility;
Reboot, and check to see if the blender icon is now visible on the desktop. If so, click it to launch blender...
menulibre https://aur.archlinux.org/packages/menulibre/ may be what you're looking for
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 3 10,350 01-09-2025, 05:02 AM
  LibreOffice usable with Arch Linux on the Pinephone? Peter Gamma 2 4,286 07-28-2024, 05:12 AM
Last Post: Peter Gamma
  stuck between phosh and plasma aular 0 2,574 02-27-2024, 05:55 PM
Last Post: aular
  Updating Arch Linux _radv_ 8 9,716 02-20-2024, 09:35 AM
Last Post: _radv_
  How to install arch with FDE user641 3 6,074 01-11-2024, 10:18 PM
  How to find software app, on Arch Phosh? general_lee 5 9,287 10-15-2023, 10:12 PM
  Arch auto mount usb example Lazy_one 2 9,544 10-06-2023, 09:36 AM
Last Post: luppivega
  Repeat previous command in console ionmich 0 2,812 08-16-2023, 08:00 AM
Last Post: ionmich
  Arch with FDE user641 1 4,066 07-29-2023, 08:27 AM
Last Post: alpineduck
  No keyboard on Arch Plasma when entering password on document Chief 0 3,405 12-03-2022, 08:35 PM
Last Post: Chief
