Cell modem
I am having a problem with cell modem. No WWAN adapter found is what I see in setting + mobile.  When I run mmcli -m O in terminal I get error: couldnt find modem and mmcli _L reveals No modems were found.  Any help would be appreciated
Do you have a sim card installed ? I think one is necessary, it can be expired or un-activated.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
as a start, command "lsusb" in a console, you should see something like this...
mobian@mobian:~$ lsusb Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 009: ID 2c7c:0125 Quectel Wireless Solutions Co., Ltd. EC25 LTE modem Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub mobian@mobian:~$
there should be quectel modem.
(09-20-2021, 02:02 AM)zetabeta Wrote: as a start, command "lsusb" in a console, you should see something like this...
Thats exactly what I see when I run lsusb.  Can you advise on any other commands or fixes.  My next move is to install a fresh OS on a SD and boot from that.  If I see the cell modem and it works I know its on the software end.
(09-19-2021, 11:01 PM)bcnaz Wrote: Do you have a sim card installed ?  I think one is necessary,  it can be expired or un-activated.
Yes I have a sim installed.  I tried a new one just cause and still nothing
Maybe a dumb question, but is your hardware kill switch active?
The switch is on the on postion.  Also no mobile config option in the settings app
Have you tried different releases ?
Not every Nightly release works "Out of the Box"
But Most Nightly releases do work... at least for me.
Nightly September 19, 20 appear to have some faults with calls, I am downloading Sept. 21 at the moment.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
(09-20-2021, 11:52 PM)bcnaz Wrote: Have you tried different releases ?
No i will try another release
Update I tried a new release and the cell modem worked
Great to hear !
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
Something in a Bookworm upgrade just broke my cellular modem. It's not there anymore. Cold reboot and even battery removal does not bring it back. I booted to the old Mobian on the Megous multi boot and it worked fine.
I've found a method to restore the modem after every Bookworm boot, but it's a PITA:
1. I run Modem Manager GUI. It detects the modem and, after I activate it with my cellular carrier using the "Activate" button, I can place calls.
However, there is no signal strength / mobile icon in the the top status bar and the "Settings" ap does not have a "Mobile" entry / button so no mobile network management features are available.
2. To make everything work again,
sudo systemctl restart phosh.service
does the trick!
Exclamation Cannot flash the modem firmware anonymous 9 13,692 12-17-2025, 01:42 AM
  Logging modem dialout attempts biketool 2 3,395 04-11-2025, 02:47 AM
Last Post: vusra
  Modem wakes for incoming call, but too slow to answer the call dchang0 8 6,653 12-01-2024, 07:54 PM
Last Post: dchang0
  MODEM - Usb problem & couldn't query SIM slots: QMI protocol freelectro 5 11,112 06-06-2023, 06:36 AM
Last Post: freelectro
  ModemManager debug mode? (Needed to flash modem) calinb 1 5,850 02-27-2023, 04:18 PM
Last Post: calinb
  Modem Firmware Upgrade - Modem Busy - USB Issues biketool 10 14,904 09-23-2022, 05:15 AM
  Phosh modem on/off effectiveness? Zebulon Walton 0 2,414 01-24-2022, 09:21 AM
  Modem suddenly not enabled when booting from eMMC Zebulon Walton 3 6,209 10-23-2021, 01:55 PM
  Using the "Modem Manager GUI" bcnaz 0 2,768 08-02-2021, 06:49 PM
Last Post: bcnaz
  Reboot Modem on Pinephone in Mobian eggmatters 5 11,231 06-17-2021, 02:08 PM
Last Post: eggmatters
