power management change?
Just noticed that after running updates today, sleep mode seems to have stopped working,  the screen wakes up after about a minute or two and stays on till I turn it off and I'm back down to 2-3 hours battery life (was about 10). Is this likely to change again with future updates? Or have I broken something enough to require a re-install?
(05-25-2020, 09:08 PM)pjsf Wrote: Just noticed that after running updates today, sleep mode seems to have stopped working,  the screen wakes up after about a minute or two and stays on till I turn it off and I'm back down to 2-3 hours battery life (was about 10). Is this likely to change again with future updates? Or have I broken something enough to require a re-install?
This seems to be a bug in the way phoc/phosh implements power management (which is a fairly new feature). This will be fixed in the (hopefully near) future.
  Power Consumption on Suspend JudgeFudge 8 7,630 07-29-2023, 06:24 AM
Last Post: JudgeFudge
  Screen stay black unless power key pressed short freelectro 0 2,365 06-24-2023, 01:55 PM
Last Post: freelectro
  Battery Management jsch 4 5,823 07-27-2022, 11:17 AM
Last Post: jsch
  Change GUI from Phost to Gnome (or anything else) johnpine 0 2,109 05-27-2022, 06:52 AM
Last Post: johnpine
  User login change usagi 11 15,029 05-13-2022, 01:16 AM
Last Post: johnpine
  Notification light when entering low power Barugon 5 7,226 11-22-2021, 06:20 AM
Last Post: beta-user
  Change default program for a file type 3x5co 1 3,653 09-01-2021, 05:26 PM
  Change locking of Ctrl modifier? vandys 1 3,365 05-08-2021, 02:46 AM
Last Post: MtnSk8
  Manjaro convergence edition (3GB) charging/power issue Saliency 1 4,100 11-24-2020, 11:04 AM
Last Post: Saliency
  USB-C Power Delivery does not work nazarii.kretovych 2 6,437 10-05-2020, 09:15 AM
Last Post: wibble
