Manjaro ARM Alpha5 for PinePhone!
Official Manjaro Forum Link
Changes since Alpha4:
  • Outgoing and Incoming Audio Call works.
  • New SMS app called spacebear, A re-write of spacebar.
  • Added some new apps.
  • Angelfish browser is quite smooth and can add webpages to homescreen.
  • Updated and more stable Plasma Mobile interface.
  • Current Alpha image is using Testing branch.
List of new Apps in Alpha5:
  • Buho - Simple Note Taking app.
  • Nota - Simple Text editor app.
  • Vvave - Audio player app. (Can play youtube Videos in it)
  • Qwikaccess - Simple shortcut buttons app
  • Peruse - Comic Book reading App.
  • Koko - Kde Plasma Image gallery.
Manjaro ARM Team.
(04-18-2020, 10:08 AM)spikerguy Wrote: Manjaro ARM Alpha5 for PinePhone!
Yesss, I've been waiting for this.
Thanks a lot!
i gave it a try, the screen movement and scaling looks good, got a check my internet connection from the "software app" updates section, tried the browser -worked ok. did not try a sim , looks nicer to work with than some plasma setups ,nice.
does it have crust firmware integrated yet?
(05-08-2020, 05:11 AM)paju1986 Wrote: does it have crust firmware integrated yet?
No Not yet. It will take sometime to get crust to work on Manjaro as it requires legacy compilers.
Manjaro ARM Team.
SMS messages didn't appear in the messaging app, so I have no idea if they send/receive properly
that said, wifi works perfectly which is ahead of UBPorts.
the app store is incredibly limited, but it gave me less trouble than the ones for UBPorts and ArchARM. I've also never ran KDE before, so some of the categories seemed to be in another language lol
from the sound properties it seemed that it has the same issue that Phosh has right now, where you need to manually toggle the audio to make a phone call, or am I wrong? I have no cell reception at my home so I honestly couldn't test it.
also, there's pacman. I severely miss pacman. that reminds me, I tried to use a PKGBUILD to manually build an app to test (a facebook messaging app), and when I tried to makepkg it complained that there was no fakeroot environment.
(07-06-2020, 06:20 PM)hiimtye Wrote: SMS messages didn't appear in the messaging app, so I have no idea if they send/receive properly
You need to install all the pkgs needed to build pkg.
Sudo pacman -S base-devel
This will get you all the pkgs like fakeroot etc.
Manjaro ARM Team.
of course! that seems so simple, and on regular Arch I'd have known that (or rather, it would've been done as part of the base install), d'oh!
For now there is availbale ALPHA-6
Installed it, booted and tested calls.
Incoming calls are recognized on the phone. It rings, but no app starts to accept the call. If You start the phone app manually there is no incoming call, but the phone rings. Outgoing works flawlessly
Something broken in the notification system?
I tested ALPHA-7.
Calls seem to work now - but no sms application installed.
Applying the update via the software store killed the system by cpu overload.
Something with the carrier signal seems to be odd too. Signal strength jumps from 0 to 40% back to 20% and 0 again.
  systemic issue pinephone penguins_rule 3 415 04-02-2024, 11:52 AM
  link for supported pinephone os manjharo et all penguins_rule 2 231 03-19-2024, 10:36 AM
Last Post: penguins_rule
  Manjaro: Settings doesnt open nbh 0 590 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 3,494 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 1,603 05-10-2023, 09:27 PM
  new PinePhone upgrade issue WhiteHexagon 5 1,808 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 807 04-25-2023, 09:49 AM
Last Post: jakfish
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 4,756 03-02-2023, 07:25 PM
  Can't add micro SD card to Pinephone thorensjubilee 7 2,527 02-27-2023, 10:21 AM
Last Post: mikehenson
  Can't install Manjaro thorensjubilee 1 1,027 02-09-2023, 08:17 AM
