Manjaro 20.04 released
>/dev/mmsbl1 ,, I hope this is a typo
You can't mount whole card, only partitions,,,, /dev/mmcblk1p1
There is a systemd service (don't know name), or try startx or init 5
I just did a google search for "manjaro pacman history" and got "cat /var/log/pacman.log" So, if you ca get to a root console you might be able to find out what you removed. You can then try to reinstall with "pacman -Si <package>". I am a debian/ubuntu user, (but have also found that Manjaro seems to be the best distro on the PBPro) so check the commands I mention by looking at the man pages for pacman first.
If you can flash a SD card, on another computer, try the 20.04 SD card version of Manjaro. If it boots, you can use it to help.
(04-06-2020, 04:48 PM)mainer Wrote: I just did a google search for "manjaro pacman history" and got "cat /var/log/pacman.log" So, if you ca get to a root console you might be able to find out what you removed. You can then try to reinstall with "pacman -Si <package>". I am a debian/ubuntu user, (but have also found that Manjaro seems to be the best distro on the PBPro) so check the commands I mention by looking at the man pages for pacman first.
Thank you. I flashed the installer image to a different SD card and I was able to re-install Manjaro. Not sure what the problem was, maybe an issue with the card I used initially.
(04-06-2020, 04:14 PM)wdt Wrote: >/dev/mmsbl1 ,, I hope this is a typo
Sorry, this was a typo I meant the partition not the device...
  Manjaro Sway Theme Broken Eighty8 1 326 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,800 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 379 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,230 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,322 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 448 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 954 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,055 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,018 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 805 08-18-2023, 02:06 AM
Last Post: juliamenendez
