Modem crashing on overheat?
Just had an issue on Debian + Phosh ( though it might well be the same on other distros) where the pinephone showed symptoms consistent with the Modem  locking up after playing  approx 10 mins  of full screen video (in firefox), the phone got very hot and  the Wifi stopped working. Software was showing it as connected but no operations had any effect ( search for networks, disable and reenable etc). on closing the phone down it hung at the backlight on, cursor in the corner stage, where it's presumably waiting for a successful shutdown response from the modem. Eventually I hard powered down and restarted and everything was back to normal.
I know that the vpu video acceleration is probably rough/non-existant and this may, in future, change and make longer video playback possible without overheating, but is there any otherway of getting the modem to "throttle" when hot?
  Modem white list aular 7 946 02-13-2024, 04:35 PM
Last Post: aular
  qcell modem id aular 6 886 01-15-2024, 10:05 PM
Last Post: aular
  Temporary fix for Modem Not Coming Back on in SXMO Postmarketos Pinephone kebab 2 2,111 07-16-2023, 11:14 AM
Last Post: kebab
  Modem gets disabled on every suspend jojuma 5 1,831 03-27-2023, 02:51 AM
Last Post: jojuma
  Modem audio settings jack1 2 1,322 02-04-2023, 04:01 PM
Last Post: jack1
  The modem switch affects the connection to battery? JohnDoe 2 2,058 03-30-2022, 12:02 AM
Last Post: JohnDoe
  Modem disabled, can't enable: Invalid transition pac 4 3,559 03-23-2022, 01:08 PM
Last Post: Firewave
Question Modem problems with the distros I tried UltraBlack_ 9 5,342 02-21-2022, 01:57 PM
Last Post: KNERD
Big Grin troubleshooting Chatty / modem? no SMS outbound vap0rtranz 5 3,678 02-14-2022, 12:15 PM
Last Post: vap0rtranz
  PinePhone Beta 3GB modem not working hannescam 15 9,138 01-19-2022, 02:08 AM
Last Post: bcnaz
