Could the display be replaced/upgraded?
I've been wishing for a better display on the pinebook pro, something with better colour. Is a display upgrade possible? What are the requirements for a panel to be compatible?
I saw a thread about display upgrades on the normal pinebook, but no results were posted by anyone.
I found these specs on the Wiki:
  • Model: BOE NV140FHM-N49
  • 1920x1080 resolution
  • 60hz refresh rate
  • IPS
  • 1000:1 contrast
  • 250nt brightness
  • 63% sRGB coverage
  • 6 bit colour
  • 30 pin eDP connection
Would any 14 inch panel with a 30 pin eDP connection work? Does it have to also be 6 bit?
I'm afraid I don't have answers to your question, but if your colors are off, have you looked into calibrating the display panel and generating a new .icc?
(03-12-2020, 04:51 AM)Ilia3101 Wrote: I found these specs on the Wiki:
  • 60hz refresh rate
  • IPS
  • 1000:1 contrast
  • 250nt brightness
  • 63% sRGB coverage
  • 6 bit colour
I would welcome a 1920x1200 panel. As a developer I am quite accustomed to the increased vertical resolution. I understand the economics of 1920x1080 but watching videos is not the only use for the PBP.
@crusty Would be nice to have 16:10 but that would require some bezel cutting/modification
@tophneal I don't own a calibrator. If I get my hands on one I'll make an icc for the pbp. But I would still want to upgrade the panel. Most software doesn't respect icc profiles, so I like having a screen that's close to sRGB.
I might try a b140han01 .2 or .3 panel, they sell cheap second hand.
  Pinebook Pro Plus (upgraded Pinebook Pro) acruhl 3 1,529 07-28-2023, 06:23 PM
  PinebookPro Display Corrupts/Cuts Out Twig 5 2,244 06-11-2023, 07:59 AM
  PBP green LED works but blank display. frerebo 1 877 02-22-2023, 03:11 AM
  Lost my second display WEF 5 3,019 08-18-2022, 07:53 AM
Last Post: josmo
  Issues with External Display After Recent Update reundo 0 1,379 11-18-2021, 06:37 PM
Last Post: reundo
  No Display on PBP PitCritter 2 2,282 09-04-2021, 12:05 AM
Last Post: lot378
  Pinebook Pro - Display cable broken? snokis 0 1,519 08-17-2021, 11:30 AM
Last Post: snokis
  pinebook pro dock display out mamboman777 0 1,513 07-29-2021, 10:41 AM
Last Post: mamboman777
  USB C dock with internal display mirrored to projector and one extended display jbrock 4 3,073 07-19-2021, 04:00 PM
Last Post: jbrock
  [split] U-Boot with NVMe support, keyboard & display working as400 83 82,642 01-27-2021, 12:48 AM
Last Post: as400
