NVME adapter
I read the thread Luke made about the NVME adapters, and I'm unsure of which I received in the mail today. That post was made in October and this one says it's a V.2 from November but I'm still unclear. I have no problem cutting it down, just don't want to if it's not needed.
Here's a pic of the board along with a usb adapter and 128gb chip. If I had to guess, I'd say the SD card adapter writes image faster but it doesn't take long either way.
Is this the new model or the old and if old, should I wait for whatever parts will be shipped.
https://imgur.com/6fUK2PB
(02-21-2020, 06:41 PM)MIchael Wrote: I read the thread Luke made about the NVME adapters, and I'm unsure of which I received in the mail today. That post was made in October and this one says it's a V.2 from November but I'm still unclear. I have no problem cutting it down, just don't want to if it's not needed.
This looks like exactly the same thing I received today. v2 does seem to indicate it's a revision so I think this should be the new version with all the parts necessary. I had no problem getting it installed in my PBP. The 500GB Samsung EVO 960 I've got works a treat.
If you have a look here https://wiki.pine64.org/index.php/Pinebo...nal_Layout you can see the NVME board in place with the ribbon cable attached but no NVME drive installed.
The catch is that you need to install the NVME drive first. This is because you need to slot the curve at the end of your NVME drive in to the groove cut in the side of the gold ring. You then secure the drive by feeding a screw from the back of the board in to the threads of the gold ring. Then you can put the board in as you see in the previous link and secure it with the three remaining screws.
http://imgur.com/a/sJIZLZu
Michael,
I just read the Feb update a few minutes ago and wondered if the NVME adapter I received this week was the new or the old model.  Fortunately, they show a picture of both in the Feb update so I checked immediately.  I got the new one.
Bill
(02-22-2020, 11:08 AM)ColoBill Wrote: I just read the Feb update a few minutes ago and wondered if the NVME adapter I received this week was the new or the old model.  Fortunately, they show a picture of both in the Feb update so I checked immediately.  I got the new one.
Bill
Thanks a ton, I must have missed the update
Https://www.pine64.org/wp-content/upload...apter.jpeg
Looks like I have the new one. M.2 will be here Monday to give it a go
  New Working nVME gilwood 0 219 02-12-2024, 08:46 AM
Last Post: gilwood
  NVME problems 2022 / Intel 660p 1TB Starbug 1 1,544 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 1,817 11-28-2022, 12:56 PM
Last Post: dachalife
  NVMe drives not detected mattpenn 12 10,419 03-05-2022, 04:53 AM
Last Post: mattpenn
  NVme intall usage? tkudog 2 2,913 03-04-2022, 01:29 AM
Last Post: Tazdevl
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 1,866 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  NVMe-related crashes and instability, plus a solution simonsouth 13 14,755 12-10-2021, 07:47 PM
Last Post: josmo
  Mini-Howto: ROCK64 USB 3.0 WIFI Adapter (Rabbit-ear) on Manjaro Dendrocalamus64 1 2,401 11-14-2021, 03:41 PM
Last Post: Dendrocalamus64
  NVMe SSD testing methodology halogen 1 2,641 07-22-2021, 05:57 PM
Last Post: calinb
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 4,798 07-09-2021, 08:45 PM
Last Post: moonwalkers
