NVMe SSD testing methodology
I want to test an NVMe SSD drive in the Pinebook Pro that isn't yet in the wiki Hardware Accessory Compatibility list. can someone please write a noob-friendly guide on how to do it? I want to find out the following:
  • whether the system can remain stable while the drive is in sustained heavy use
  • APST default setting
  • whether the power settings are saved across reboots, and if not, is there a workaround
(07-20-2021, 10:44 AM)halogen Wrote: I want to test an NVMe SSD drive in the Pinebook Pro that isn't yet in the wiki Hardware Accessory Compatibility list. can someone please write a noob-friendly guide on how to do it? I want to find out the following:
This is the guide I used:
https://eli.gladman.cc/blog/2020/06/23/p...-nvme.html
And of course the wiki:
https://wiki.pine64.org/wiki/Pinebook_Pr...Me_adapter
I found that Manjaro can boot off the NVMe SSD (both boot and / from the NVMe are mounted). However, Manjaro's U-Boot must be present on the eMMC too. Details of my learnings are in my thread here. Read the entire thread as I learn from Manjaro mod, Stritt:
https://forum.manjaro.org/t/pinebook-pro...nvme/72770
As you can see from the title of the thread, I also discovered that Linux.org broke the NVMe boot in going from 5.12.11-1  to 5.13.0-1! I've not had time to test Stritt's theory by putting "CONFIG_PCI_MSI_ARCH_FALLBACKS=y" and the associated msi_controller driver code back into the 5.13 Manjaro kernel source and rebuilding the kernel to see if that fixes it. Details are provided in the thread. I'm still running 5.12.11-1 for this reason.
I'm running the 1TB WD Blue SN550 (‎WDS100T2B0C). In my ad hoc testing, APST mode (the default) seems to work very well and I'm not motivated to try static power settings.
Oops--I forgot to include this thread too:
https://forum.manjaro.org/t/re-partition...sd/72463/2
  New Working nVME gilwood 0 221 02-12-2024, 08:46 AM
Last Post: gilwood
  NVME problems 2022 / Intel 660p 1TB Starbug 1 1,544 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 1,817 11-28-2022, 12:56 PM
Last Post: dachalife
  NVMe drives not detected mattpenn 12 10,419 03-05-2022, 04:53 AM
Last Post: mattpenn
  NVme intall usage? tkudog 2 2,914 03-04-2022, 01:29 AM
Last Post: Tazdevl
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 1,866 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  NVMe-related crashes and instability, plus a solution simonsouth 13 14,755 12-10-2021, 07:47 PM
Last Post: josmo
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 4,798 07-09-2021, 08:45 PM
Last Post: moonwalkers
  nvme drive disappears after about an hour of uptime codebreaker 25 32,190 02-09-2021, 11:32 PM
Last Post: dsimic
  NVME SPI Update not booting SD Card WZ9V 5 6,432 10-18-2020, 08:36 PM
