Single Thread for Problem Status's
Hello there!
I've been piddling with my 2G board for a little while and, of course, had the usual set of issues that happen. I'm not even slightly annoyed by this as I know what I was getting myself into backing a project like this! On that note, I'd like to thank the devs and the team for all of their hard work and for putting up with the angry people who need a time out and a cookie.
But, one thing I think people would find really helpful is a single location summary of known bugs, and their workarounds. Maybe there could be sticky thread places somewhere, and categorize them by general group, and then put the higher priority/greater group affected first.
A good example is I've been having the "purple screen" issue caused by using an HDMI->DVI adapter. When it first happened, it would have been wonderful to know that that was a problem.
Anyhoo, just my two cents.
This would be helpfull.
Sent from my SM-G900T using Tapatalk
Just so you know those places do exist.
For Linux
http://forum.pine64.org/showthread.php?tid=598
For Android
http://forum.pine64.org/showthread.php?tid=791
For Remix OS
http://forum.pine64.org/showthread.php?tid=792
I developed the bug tracking system for the Forums on an external site that links everything back to here.
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
  Jack connector problem pinebug 1 5,341 11-10-2024, 01:13 PM
Last Post: gadgetguy
Question External storage problem for pine64 Dani6102 3 7,590 07-26-2023, 10:57 AM
  Need Sollution : Screen Problem and says the Error "Out of Range" on the display hunterzonecss 2 6,843 04-19-2019, 08:26 AM
Last Post: psychedup
  problem connecting to Pine 64 store stephen fleming 2 7,554 09-24-2016, 08:57 PM
Last Post: stephen fleming
  Order status, please help johntron25 8 17,428 07-08-2016, 12:40 PM
  Order Status prefontaine 3 8,499 06-26-2016, 10:16 PM
  Problem making SD card Tam Dl 17 34,684 06-19-2016, 07:48 PM
Last Post: pfeerick
Sad display problem florianl 5 11,946 04-29-2016, 08:53 AM
Last Post: Luke
