Bug Reports - Android Lollipop - Report Them Here
Last Updated - May 5th 2016 - 10:43am EDT
How To Submit
To help facilitate things please include the following information when submitting a bug report at www.pine64.pro
  • Pine 64 Model (A64 512 MB, A64+ 1 GB, A64+ 2 GB)
  • Operating System (Debian, Ubuntu, Arch)
  • Equipment Involved (Routers, Switches, Peripherals, Etc)
  • Issue (Whatever It May Be)
Before submitting a new bug report please check to see if there is already an issue listed in either the Bugs Reported, Bugs Confirmed or Bugs Repaired section that matches yours. If an issue that matches yours has been submitted then simply Contribute to that report.
If there is not an issue that matches yours listed then please submit a new bug report via the form included in the New section.
Pine64 Pro Team.
REPORTED BUGS
This section contains bugs that have been reported but not confirmed. When enough community members and the Pine64.Pro team have confirmed the existance of the bug(s) posted here it will then be moved into the Bugs Confirmed section.
Wacom driver rotates, should not
  • Reported By: hyperlogos at pine64.pro
  • Reported On: May 5th 2016 - 10:43am EDT
  • Pine 64 Model: Pine A64+ 2 GB
  • Operating System: Release 3
  • Equipment Involved: Input Devices
Wacom graphire on Android build 20160428. When the screen rotates, the tablet input also rotates. It should not do this. This was supposed to be fixed in the wacom driver for Lollipop, according to Wacom... this makes it impossible to click on items at the "bottom" (right) of the screen.
Total Reports: 1
View full report here www.pine64.pro
Problem placing widgets
  • Reported By: fsa317 at pine64.pro
  • Reported On: May 3rd 2016 - 7:03pm EDT
  • Equipment Involved: Choose Equipment Involved
Most widgets, when I try to place them on my home screens hang and fail. I found this in the log (similar messages for lots of widgets):
This is consistent whenever a widget has a "configuration" screen after placing it. Widgets without a configuration screen seem to work OK.
05-03 15:20:07.758: E/AndroidRuntime(18457): Process: com.android.launcher3, PID: 18457
05-03 15:20:07.758: E/AndroidRuntime(18457): java.lang.NullPointerException: Attempt to invoke virtual method 'boolean com.android.launcher3.CellLayout.findCellForSpan(int[], int, int)' on a null object reference
05-03 15:20:07.758: E/AndroidRuntime(18457): at com.android.launcher3.Launcher.completeAddAppWidget(Launcher.java:1623)
05-03 15:20:07.758: E/AndroidRuntime(18457): at com.android.launcher3.Launcher.completeAdd(Launcher.java:727)
05-03 15:20:07.758: E/AndroidRuntime(18457): at com.android.launcher3.Launcher.finishBindingItems(Launcher.java:4516)
05-03 15:20:07.758: E/AndroidRuntime(18457): at com.android.launcher3.LauncherModel$LoaderTask$10.run(LauncherModel.java:2764)
05-03 15:20:07.758: E/AndroidRuntime(18457): at com.android.launcher3.DeferredHandler$Impl.handleMessage(DeferredHandler.java:51)
05-03 15:20:07.758: E/AndroidRuntime(18457): at android.os.Handler.dispatchMessage(Handler.java:102)
05-03 15:20:07.758: E/AndroidRuntime(18457): at android.os.Looper.loop(Looper.java:135)
05-03 15:20:07.758: E/AndroidRuntime(18457): at android.app.ActivityThread.main(ActivityThread.java:5254)
Total Reports: 1
Bluetooth not working
  • Reported By: Tarjei85 at pine64.pro
  • Reported On: May 1st 2016 - 12:09pm EDT
  • Equipment Involved: Bluetooth
Not able to enable the BT in build **0428 [BETA].
When I try to enable it it stays in the on-position for a coupple of seconds before snapping back to off.
Total Reports: 2
Screen Cropped
  • Reported By: al at pine64.pro
  • Reported On: April 27th 2016 - 2:29pm EDT
  • Equipment Involved: Video/Display
i'm experiencing a cropped display on all 4 edges so the available OSs are note usable.
at least 50px are missing on each side.
tested hardware:
-HP w2448hc (1080p-compatible)
-3 different HDMI cables
i tested the following OSses and the behaviour is the same for all:
-xubuntu-xenial-20160421-longsleep-pine64-8GB (already cropped while booting)
-remix-v2.0-20160415-pine64-8GB
-android-ver5.1.1-20160303-pine64-8GB
On another Samsung tv (720p-compatible) the TV gives me a "not supported display mode" for all cables and all OSses.
So there is no chance for me right now to use the PINE at all.
I'm hoping for a fix!
cheers
Total Reports: 3
Google Play Services Crashes
  • Reported By: CptMonkeyFist at pine64.pro
  • Reported On: April 25th 2016 - 11:58pm EDT
  • Pine 64 Model: Pine A64+ 1 GB
I booted up the 20160303 Android image, connect via WIFI (worked great), and start chrome to test internet connectivity. It crashes so I check the forums which say to uninstall+reinstall Chrome. I open up google play, search for chrome, uninstall it from google play, and reinstall. Everything is working fine so far. I can open chrome without crashing, BUT it says that to use Chrome I must have the most recent version of Google Play Services.
I ignore the "Google is enforcing their verified devices, DON'T DO IT" feeling in my gut and update Google Play services. Chrome now works, but Google play crashes whenever I try to search or open details of an app saying "Unfortunately, Google Play Store has stopped". I've been wanting to try Remix OS for a while and it will probably suit my purposes better anyway. I'll post more details if I run into the same problem with that OS.
Total Reports: 1
CONFIRMED BUGS
This section contains bugs that have been confirmed by various sources. Details and explanations of these bugs will be provided to further enhance the knowledge base of the community until a solution is developed and fully tested.
No Confirmed Bugs
REPAIRED BUGS
This section contains the solutions and workarounds for bugs that have been confirmed. These solutions may be operating system specific or will work in general for all systems.
No Repaired Bugs
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
  Need help compiling android for pine a64 + YeeticusMaximus22 2 2,533 08-20-2026, 08:45 AM
Last Post: ahegarosib97
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 606,130 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 50,052 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 31,962 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,657 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 14,202 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,538 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,719 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 408,768 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 7,475 02-26-2019, 11:58 AM
Last Post: Twistedx
