display problem
Sad
i powering up the pine 64 2gb and nothing in the screen  . i tried different screen and cables and none of them getting singles
i Installed the software like he did in the video and noting happening when i turn it on
https://www.youtube.com/watch?v=TjJ62s5D...e=youtu.be
Pine64 2GB is pushing 1080p/60Hz signal (I don't understand this very well), you need monitor which is able to handle it. If your monitor is for example 1050p/60Hz native, it won't power up.
You can try it using HD TV if you have some (1080p).
You also pretty much HAVE to use an HDMI cable. You can't use an HDMI to DVI adapter. I found that out the fun way as well.
Just to report that I successfully used HDMI to DVI adapter on Pine 2GB without any issue. Monitor is Crossover 3020mdp (2560x1600). Unfortunetly I do not know the model of the adapter.
(04-27-2016, 04:45 PM)baryluk Wrote: Just to report that I successfully used HDMI to DVI adapter on Pine 2GB without any issue. Monitor is Crossover 3020mdp (2560x1600). Unfortunetly I do not know the model of the adapter.
I too sucessfully used a HDMI to DVI adapter BUT the blacks appear as purple... I used it only for initial testing.
Hey, please see this thread I've created as an ad-hoc solution to this problem: http://forum.pine64.org/showthread.php?tid=827
What type of cable/adapter are you using ?
  Jack connector problem pinebug 1 5,226 11-10-2024, 01:13 PM
Last Post: gadgetguy
Question External storage problem for pine64 Dani6102 3 7,426 07-26-2023, 10:57 AM
  Need Sollution : Screen Problem and says the Error "Out of Range" on the display hunterzonecss 2 6,784 04-19-2019, 08:26 AM
Last Post: psychedup
  No HDMI Display need help with correct uEnv.txt settings dkebler 7 16,925 01-11-2018, 02:52 PM
Last Post: dkebler
Rainbow Pine64 + waveshare display? iPhyse 4 11,658 10-12-2016, 04:43 PM
Last Post: hamzahbondok
  problem connecting to Pine 64 store stephen fleming 2 7,482 09-24-2016, 08:57 PM
Last Post: stephen fleming
  Problem making SD card Tam Dl 17 34,461 06-19-2016, 07:48 PM
Last Post: pfeerick
  Single Thread for Problem Status's gbestwick 2 6,049 05-03-2016, 07:28 PM
Last Post: lenny.raposo-pine64.pro
  nexdock (laptop style HDMI display w/ BT keyboard/touchpad) neoaeon 5 13,050 03-10-2016, 07:43 PM
Last Post: hrh1818
