Pinebook Pro Revised Keyboard Firmware
#41
(02-13-2020, 10:03 PM)ab1jx Wrote: I tamed my touchpad by making it generic.  All I ever wanted was a touchpad like from 10 years ago: X & Y movement, 2 buttons, scroll wheel emulation.  The PBP touchpad by default is trying to be a "clickpad" (google it), it has "gestures" which would be more appropriate on a touchscreen.  I use the libinput driver and only the libinput driver.  I'm not sure how libinput got there, I don't remember if I installed it or not.  Remove or disable by renaming to not have a .conf extension (like .off ?) your synaptics and mtrack files in /usr/share/X11/xorg.conf.d.  synclient won't work anymore.
< SNIP >
Does this work equally in Wayland, or is it exclusive to X-Sessions?
— Jeremiah Cornelius
Hi @jackhumbert
I tried to update my ISO keyboard with @ayufan updater and experienced the following error https://github.com/ayufan-rock64/pineboo.../issues/19
The error occurs during Step-2. I tried it on Debian via sdcard and via emmc on manjaro 20. The same error occurs with your updater>
Running STEP-2...
[*] Flashing touchpad firmware...
[*] Opening in touchpad mode
>>> Trying to open VID:258a PID:001f...
>>> Kernel Driver Active
>>> Verify mismatch: type=f2, pass=e2, received=d2
[repeated ...]
>>> Touchpad verify (type=242, pass=226) data failed
>>> Touchpad erase failed
>>> release interface
I would really appreciate any help since I tried every suggestions documented in the other threads in this forum. I guess when you test any new releases you got a rollback scenario how to patch in the old firmware.
Appreciate any help
Did you restart at step 1?
(03-18-2020, 01:13 PM)xmixahlx Wrote: Did you restart at step 1?
Yes, I tried:
- to do everything via ssh, tty, gui shell
- reboot after step-1
- reboot with complete shutdown for a couple of minutes
- with/without attached usb keyboard
- with/without attached usb mouse
- on debian via sdcard
- on manjaro 20 on emmc
- multiple times
Regards for your reply
I'm also having the same issue as Cloudnaut, having tried all the same steps.
Question,, is this the shutdown from HOLDING pwr button for 15+ seconds? (for me, 20+sec),
for a COMPLETE shutdown?
Did you avoid starting X, at dm (sddm, ldm,whatever) DON'T login, switch to vt and login root?
You could try single mode, add "1" (no quotes) to kernel cmd line in extlinux.conf,
if successful login will be text mode in vt1
(if boot.txt/boot.scr need to recompile scr, with uEnv maybe just in that)
(03-20-2020, 01:21 PM)wdt Wrote: >- reboot with complete shutdown for a couple of minutes
ok, tried that:
systemctl disable lightdm # so do dm was running anymore after boot
  • as you said, after a shutdown I held the POWER Button 20 seconds
  • executed step-2 after reboot and then I got a segmentation fault
  • Then I started from the beginning again with step-1 a couple of times but now after step-2 the verify mismatch error occurs again
I didn't manage to start in single mode, I added the 1 to the /sbin/init 1 command but then on boot I only got a black screen
Please have a look at https://github.com/ayufan-rock64/pineboo.../issues/19 how I got it working again (dirty but for me this was a last resort)
Hi!
I was trying to to flash my trackpad&keyboard firmware from Manjaro ARM 20.04 and messed up my trackpad.
Compiling was effortless, and ran without errors. However flashing went wrong:
peter@pipro pinebook-pro-keyboard-updater]$ sudo ./updater step-1 iso
[sudo] password for peter:
Running STEP-1...
[*] Flashing keyboard updater firmware...
>>> Fix hex file
[*] Opening in user mode...
>>> Trying to open VID:258a PID:001e...
[*] Sending command to switch to boot mode...
[*] Command send
>>> release interface
[*] Opening in boot mode
>>> Trying to open VID:0603 PID:1020...
>>> Device not found
>>> Device not found
>>> Device not found
>>> Device not found
>>> Device not found
>>> Device not found
>>> Device not found
>>> Device not found
>>> Device not found
[*] Erasing flash
[*] Writing firmware...
>>> USB: write_block_start (length=14336)
>>> USB: write_block (offset=0, length=2048)
>>> USB: write_block (offset=2048, length=2048)
>>> USB: write_block (offset=4096, length=2048)
>>> USB: write_block (offset=6144, length=2048)
>>> USB: write_block (offset=8192, length=2048)
>>> USB: write_block (offset=10240, length=2048)
>>> USB: write_block (offset=12288, length=2048)
[*] Reading back firmware...
>>> USB: read_block_start (length=14336)
>>> USB: read_block (offset=0, length=2048)
>>> USB: read_block (offset=2048, length=2048)
>>> USB: read_block (offset=4096, length=2048)
>>> USB: read_block (offset=6144, length=2048)
>>> USB: read_block (offset=8192, length=2048)
>>> USB: read_block (offset=10240, length=2048)
>>> USB: read_block (offset=12288, length=2048)
[*] Comparing firmwares...
[*] Reseting device?
[*] Finished succesfully!
>>> release interface
[*] Please reboot now, and run `step-2`.
I have rebooted, then continued step-2:
[peter@pipro pinebook-pro-keyboard-updater]$ sudo ./updater step-2 iso
Running STEP-2...
>>> Writing offset:0 length:1024...
>>> Verifying '1k-data'...
>>> Writing offset:1024 length:1024...
>>> Writing offset:2048 length:1024...
>>> Writing offset:3072 length:1024...
>>> Writing offset:4096 length:1024...
>>> Writing offset:5120 length:1024...
>>> Writing offset:6144 length:1024...
>>> Writing offset:7168 length:1024...
>>> Writing offset:8192 length:1024...
>>> Writing offset:9216 length:1024...
>>> Writing offset:10240 length:1024...
>>> Writing offset:11264 length:1024...
>>> Writing offset:12288 length:1024...
>>> Writing offset:13312 length:1024...
>>> Writing offset:14336 length:1024...
>>> Writing offset:15360 length:1024...
>>> Writing offset:16384 length:1024...
>>> Writing offset:17408 length:1024...
>>> Writing offset:18432 length:1024...
>>> Writing offset:19456 length:1024...
>>> Writing offset:20480 length:1024...
>>> Writing offset:21504 length:1024...
>>> Writing offset:22528 length:1024...
>>> Writing offset:23552 length:1024...
[*] Verifying 'end-program'...
[*] Verifying 'checksum'...
>>> Verify mismatch: type=f5, pass=e5, received=d5
[*] Verifying 'program'...
>>> release interface
[*] Flashing ISO keyboard firmware...
>>> Fix hex file
>>> Device not found
[*] Command send
>>> release interface
>>> Device not found
>>> Device not found
>>> Device not found
>>> Device not found
>>> Device not found
>>> Device not found
>>> Device not found
>>> Device not found
>>> Device not found
>>> Device not found
[*] Erasing flash
>>> release interface
[*] All done! Your keyboard and touchpad should be updated.
I have rebooted, but the trackpad is gone! At least the keyboard works...
I tried to reboot  & redoo both steps, recompile with disabled error checking (from the previous posts, editing the sources).
This was my second attempt, previously I did successfully update the trackpad firmware but from the raspbian image.
I'm quite unsure what else could I do, so I would really appreciate any ideas!
BR
Woland
Try flashing with a mrfixit boot?
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 2 528 04-09-2024, 04:33 AM
Last Post: maxjrh
  Pinebook Pro on Debian 12 Power Issue u974615 1 331 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 274 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 609 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,076 11-07-2023, 10:09 AM
Last Post: DrYak
  Separate ISO keyboard for PBP Besouro 0 706 06-04-2023, 02:51 PM
Last Post: Besouro
  PineBook Pro dead ottahe 9 5,989 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,404 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 135,297 11-30-2022, 04:28 PM
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 1,888 10-21-2022, 07:57 AM
Last Post: dachalife
