Replacement battery for PineBook Pro
hi!
After 4 years of use, the battery of my PineBook Pro is really swollen, I should change it soon~ish.
Currently, it seems out of stock on the official store, and the European store doesn't even sell spare batteries.
So: has anyone had success procuring batteries elsewhere?
I haven't yet, but just a quick search turns up several that look like they would work, including this one
https://www.cdrtd.com/products/laptop-ba...-5pin.html
:wq
[ SRA accepts you ]
(09-25-2023, 07:12 AM)KC9UDX Wrote: I haven't yet, but just a quick search turns up several that look like they would work, including this one
That one specifically is not compatible, it's the 5pin variant, whereas the Pinebook Pro uses the 7pin avriant instead.
But cdrtd seem to have that one too.
But I don't know how much cdrtd is a reliable source for laptop parts. I've also found several vendors on AliExpress (random example), but same caveats apply: I don't know them, and I don't know anything about their reliability.
(09-25-2023, 09:44 AM)DrYak Wrote: I've also found several vendors on AliExpress (random example), but same caveats apply: I don't know them, and I don't know anything about their reliability.
Update regarding my battery problem:
  • still no answer from Pine64 themselves
  • but since then I bought one from Ali mentionned above, replaced it, charged it, seems to work.
I'll update in a few weeks whether this battery still holds charge or if it degraded too quick.
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 2 536 04-09-2024, 04:33 AM
Last Post: maxjrh
  Lithium Battery Connector Franestra 0 126 04-02-2024, 01:52 AM
Last Post: Franestra
  Pinebook Pro on Debian 12 Power Issue u974615 1 336 03-13-2024, 10:46 AM
Last Post: u974615
  Bad replacement battery? chris88233 3 388 02-19-2024, 04:59 PM
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 280 02-17-2024, 07:06 PM
  Bypassing the Battery gilwood 0 242 02-01-2024, 10:45 AM
Last Post: gilwood
  Pinebook Pro charging issues tomekdev 1 614 01-05-2024, 08:40 PM
Last Post: tomekdev
  PBPro Battery specification Perl6_user 3 576 12-26-2023, 04:28 PM
Last Post: DrYak
  Replacement main board for Developers mozes 10 1,763 11-27-2023, 04:14 AM
Last Post: mozes
  Battery replacement mjc 2 2,884 09-26-2023, 01:08 AM
Last Post: david-lechner
