Decent Pinebook Pro barrel PSU / Charger
As it might help...
This is a decent 5V 4A barrel charger for the Pinebook Pro (European plug) that is much better than the original piece of crap :
https://www.amazon.fr/gp/product/B07L63Q66R/
At least I now can use the Pinebook Pro and get it to charge simultaneously, with a decent length cable as well.
(My original provided crappy “charger” died on me after less than a month...)
Have done the same here in the U.S. Original charger's plug fell apart in the first few uses.
 while(!(succeed=try()));
Bought a dell usb-c charger, clueless about where I left the original charger ;-)
I'm 2 months with the original charger that you can swap out plugs with and no issues. I bought the dock & use a powered USB hub for external hard-drives. The original PinePhone USB-C docking bar (in the convergence kit) also works with the PBP.
Satisfied PinePhone, Pinebook Pro & PineTab2 owner; Thank you Pine64Team for your work!  Smile
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 2 528 04-09-2024, 04:33 AM
Last Post: maxjrh
  Pinebook Pro on Debian 12 Power Issue u974615 1 331 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 274 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 609 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,076 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 129,954 09-13-2023, 03:43 AM
Last Post: k3dAR
  Sanity check on spliced charger jcun4128 12 2,849 05-10-2023, 05:23 AM
  PineBook Pro dead ottahe 9 5,989 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,402 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 135,269 11-30-2022, 04:28 PM
