Wifi icon dissaperread
I was changing the appearence of the top menu, when the wifi icon had disappeared and I'm not able to show it again.
I can connect the wifi, but I have no access to the manager in order to enter to new wifi...
Could someon help please?
Thanks!
Finally I got my problem solved. I changed some days ago the looking of the desktop by using the MATE tweaks and leaving it as FEDORA looking, once I saw this, I just got back to the default configuration and the wifi icon appeared again.
(01-14-2020, 04:15 AM)gimy16 Wrote: Finally I got my problem solved. I changed some days ago the looking of the desktop by using the MATE tweaks and leaving it as FEDORA looking, once I saw this, I just got back to the default configuration and the wifi icon appeared again.
Hello gimy16.
Good to see you resolved your problem, and thanks for posting your analysis here for the rest of us.  I don't mean to hijack your thread but I had something similar happen and wanted to post about it here in case they are related.  I got my PBP yesterday, and on initial power up, it rebooted as expected and all was well.  I ran the updater from the toolbar which worked perfectly, then rebooted.  When the desktop loaded again, I moved the menu bar from the bottom to the top of the screen, and then to the left edge of the screen, which is where I usually have it.  It was only then that I saw the "menu" icon had disappeared from the menu bar.  Interestingly, I could hit the "pine key" and the menu still wouldn't show up.  I then ran the widevine installer, rebooted, and the menu icon was back, and the pine key activated it again as well.
These may be unrelated, but in case they are...
Have a great day,
Bill
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 906 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,070 07-15-2023, 02:58 PM
Last Post: u974615
  5GHz wifi not working snorwood 11 5,607 01-16-2023, 03:41 PM
Last Post: ehcorn
  Pinebook Pro wifi not working Queliffrel 1 1,317 11-30-2022, 06:30 AM
Last Post: myself600
  WiFi stopped on Pinebook Pro after update tkudog 3 2,624 11-24-2022, 04:32 PM
Last Post: tkudog
  Archlinux - missing firmware for wifi adapter RudderDuck 9 4,680 11-07-2022, 04:56 PM
Last Post: wgahnagl
  Help with Kali Linux wifi not working but works with Manjaro PineSupporter 2 2,386 08-25-2022, 02:15 PM
Last Post: Niko
Information Found newer firmware for broadcom wifi (brcmfmac43456-sdio) cobratbq 2 3,003 04-12-2022, 02:36 PM
Last Post: cobratbq
  Pinebook Pro wifi not working seyo-iv 2 3,802 10-26-2021, 02:27 AM
Last Post: wangyukunshan
  Fresh Manjaro+KDE install, strange bug hovering over the interfaces-systray icon QuinTeknoLife 1 2,052 04-29-2021, 07:13 PM
Last Post: carlosqueso
