Question to anyone with entire system on NVMe
SD cards all have one common problem. They are just not trustworthy. It's just a matter of time when you end up with broken sd card or irreversible filesystem error.
P.S. My ANSI PBP just came this minute Tongue
well, I wonder about the uSD slot, is it 50 mHZ (nibbles) or uhs104
>They are just not trustworthy (uSD)
It depends, consider thr raspberry and armbian experience
With rasp, the biggest problem is undervoltage, from a crappy cable and connector
With armbian, crappy cards, they all shout "test with iozone"
If you have a quality card, not undervolted, not 80+% full,,
the card should have a reasonable life
If the card is only 1/2 full, lots of room for wear leveling
And if you test with iozone, you quickly realize
that 90% of cards are crap for SBC purposes, OK for cameras
(and that's fair, that is what they were made for)
There is an immense amount of ignorance about flash,
exploited by the makers. More for less is good, right?
Not in this case, example SLC ->MLC ->TLC ->QLC,, bigger, better, right?
NO
voltage levels = bits
SLC (0, 1),,,MLC(0, 1/2, 1),,, TLC(0, 1/3, 2/3, 1),,,QLC(0, 1/4, 1/2, 3/4, 1)
It should be obvious which will last longer, but unfortunately smaller
And when they say "Made for FAT" that means the first 1G are written SLC
so that the MBR and PBR and FAT table are reliable
So, older (4 year) cards, if a reasonable size and quality are quite valuable
If made with quality cells, SLC, unless you are really hammering it, will
last until you lose it
You can see that in the newest nvme controllers, a new drive is 1/2 SLC, as cache,
shrinking to 10% as the drive fills
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 334 03-01-2024, 06:46 PM
Last Post: Puckla
  Fedora 36 -> 37 upgrade kills system tydeman 0 455 10-28-2023, 09:53 AM
Last Post: tydeman
  Issue with booting Manjaro from encrypted NVMe drive on pbp Cs137 1 978 08-18-2023, 01:58 AM
Last Post: juliamenendez
  NVME fails detection our0 1 818 01-30-2023, 08:45 AM
Last Post: Tazdevl
  Is anyone successfully running guix system on PBP bluekeys 8 8,001 08-29-2022, 01:19 PM
Last Post: bluekeys
  what is the magic dd incantation to copy the system from the sd card to the emmc? geokon 18 9,322 08-18-2022, 11:26 PM
Last Post: calinb
Bug Pinebook Pro NVME stopped working secretagentdude 4 5,426 12-17-2021, 06:23 PM
Last Post: pinemouth
  NVMe timeout when booting from eMMC but not SD satwell 5 5,589 10-29-2021, 07:41 AM
Last Post: psstoev
Question Can't boot any operating system other than Fedora after following the nullr0ute guide TDC_PBP 1 2,451 10-09-2021, 07:35 PM
Last Post: TangoZuluTango
  Managing cpu voltage and clock speeds question. FeMike 5 6,374 05-24-2021, 10:17 PM
Last Post: generaleramon
