NVME fails detection
My setup :
- latest arm64 Kali, with kernel 6.0.0-kali5-arm64
- latest tow-boot 2021.10-005 on SPI
Kingston A2000 M.2 2280 NVME 1 To (one of the best supported drives from wiki list)
My problem : On boot, nvme is detected but I get a rescue console on every boot.
My "ugly" fix :
modprobe -r nvme
modprobe nvme
exit console
I get a normal boot
On logs (with |grep -i nvme):
[    7.298134] nvme nvme0: pci function 0000:01:00.0
[    7.298238] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[  68.575114] nvme nvme0: I/O 8 QID 0 timeout, disable controller
[  68.683053] nvme nvme0: Device shutdown incomplete; abort shutdown
[  68.703561] nvme nvme0: Identify Controller failed (-4)
[  68.703769] nvme nvme0: Removing after probe failure status: -5
[  86.189969] nvme nvme0: pci function 0000:01:00.0
[  86.195630] nvme nvme0: missing or invalid SUBNQN field.
[  86.208844] nvme nvme0: 6/0/0 default/read/poll queues
[  86.219019]  nvme0n1: p1 p2
My extlinux section :
label l0
menu label Kali Linux 6.0.0-kali5-arm64
linux /boot/vmlinuz-6.0.0-kali5-arm64
initrd /boot/initrd.img-6.0.0-kali5-arm64
fdtdir /usr/lib/linux-image-6.0.0-kali5-arm64/
append root=UUID=24ac514d-0b32-4e31-9cd1-a2e3ad3c6ead console=tty1 ro rootwait
Sorry, no fix... Subscribed to follow.
I use my PBP primary with kali and your question might help me fix issue's I have with rebooting with the old way of things before tow-boot.
  Issue with booting Manjaro from encrypted NVMe drive on pbp Cs137 1 905 08-18-2023, 01:58 AM
Last Post: juliamenendez
Bug Pinebook Pro NVME stopped working secretagentdude 4 5,244 12-17-2021, 06:23 PM
Last Post: pinemouth
  NVMe timeout when booting from eMMC but not SD satwell 5 5,418 10-29-2021, 07:41 AM
Last Post: psstoev
  Anyone can get deep sleep fully works with NVME rootfs? plumlis 0 2,007 01-11-2021, 09:58 AM
Last Post: plumlis
Bug eMMC Fails After Suspend Lodj 3 3,817 11-16-2020, 11:06 PM
Last Post: ab1jx
  Compile of Anbox fails because kernel function kallsyms_lookup_name() is unexported Tsvi Bar-David 6 7,484 06-30-2020, 06:41 AM
  How to boot from eMMC but have root directory on an NVME? QazTheWsx 7 9,266 06-26-2020, 08:20 AM
Last Post: QazTheWsx
  NVME dirive doesn't show up rleasle 3 4,052 03-15-2020, 02:39 PM
Last Post: rleasle
  Question to anyone with entire system on NVMe as400 11 10,139 01-10-2020, 01:06 PM
Exclamation Help moving rootfs to SSD (nvme). cristobalhdez 8 8,951 11-13-2019, 01:08 AM
Last Post: hdk
