Pinebook Pro NVME stopped working
Bug
Got my Pinebook Pro in earlier this week and have been loving it. Using it with a P1 Crucial NVMe M.2 as the OS drive /boot/ and / . I have wrote the updated uboot to the SPI to boot directly to the NVMe. Laptop had been working great until the battery died for the first time yesterday. Since then I've been unable to boot from the drive nor mount it in any OS. I've install Manjaro XFCE on the EMMC for now, but would like to regain use of the NVME drive.
I have tried mounting the drive on another Linux box with a USB enclosure and everything worked great. All my files are there and it mounted without issue. I've booted into OSes on SD and EMMC and have had no success seeing the SSD with the PBPro. Uboot does list the SSD on boot, but would fail to boot after 3 minutes of trying everytime. I have backed up and zeroed out the boot partition to see if I could mount it as a home drive with something booting off emmc. [Image: lItnrht] ( https://imgur.com/lItnrht )
Booting of emmc this is the error in dmesg. Any help would be appreciated, I'm kinda stumped to be honest
[    3.089584] nvme nvme0: pci function 0000:01:00.0
[    3.089877] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[   64.478617] nvme nvme0: I/O 4 QID 0 timeout, disable controller
[   64.598418] nvme nvme0: Device shutdown incomplete; abort shutdown
[   64.599337] nvme nvme0: Identify Controller failed (-4)
[   64.599812] nvme nvme0: Removing after probe failure status: -5
Have you already used nvme-cli to set your nvme to the lowest possible power state? it could also be worth trying to disable the drive's APST. https://forum.pine64.org/showthread.php?...1#pid87711
(06-07-2021, 07:01 AM)tophneal Wrote: Have you already used nvme-cli to set your nvme to the lowest possible power state? it could also be worth trying to disable the drive's APST. https://forum.pine64.org/showthread.php?...1#pid87711
 I had not yet set power states for the SSD, at the moment running
nvme scan
yields no results
nvme scan
yields no results
I have updated my extlinux.conf, nothing has changed but I wanted to mark it as another thing I've tried.
nvme_core.default_ps_max_latency_us=5500
Did it ever start working again in the PBP?
  Debian on Pinebook Pro u974615 7 970 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,515 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,120 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,186 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 88,413 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,210 11-23-2023, 07:37 AM
  USB 3 port not working with Armbian zaius 3 838 11-13-2023, 01:54 PM
Last Post: zaius
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,227 08-31-2023, 04:20 PM
Last Post: TRS-80
  Camera not working with Cheese cypresstwist 1 1,229 08-18-2023, 02:02 AM
Last Post: juliamenendez
  Issue with booting Manjaro from encrypted NVMe drive on pbp Cs137 1 964 08-18-2023, 01:58 AM
