Samsung 970 EVO SSD 1TB - M.2 NVMe works on workstation but not Pinebook Pro
I have a Samsung 970 EVO SSD 1TB - M.2 NVMe in a SSK Aluminum M.2 NVME external case, see here for the product on Amazon: https://www.amazon.com/gp/product/B07MNF...UTF8&psc=1
I installed the gnome-disks utility on the Pinebook Pro to assist me with this.
NVMe and enclosure work without problem on my workstation running Fedora 30. Format, partition, read, write, all good.
dmesg reports:
[341405.622922] usb 6-2: new SuperSpeed Gen 1 USB device number 6 using xhci_hcd
[341405.635207] usb 6-2: New USB device found, idVendor=152d, idProduct=0562, bcdDevice= 2.06
[341405.635211] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[341405.635214] usb 6-2: Product: SSK Storage
[341405.635215] usb 6-2: Manufacturer: SSK
[341405.635217] usb 6-2: SerialNumber: DF56419883E5B
[341405.823661] usb 6-2: USB controller 0000:0c:00.0 does not support streams, which are required by the UAS driver.
[341405.823667] usb 6-2: Please try an other USB controller if you wish to use UAS.
[341405.823671] usb-storage 6-2:1.0: USB Mass Storage device detected
[341405.824043] scsi host15: usb-storage 6-2:1.0
[341406.842939] scsi 15:0:0:0: Direct-Access     SSK                       0206 PQ: 0 ANSI: 6
[341406.843583] sd 15:0:0:0: Attached scsi generic sg8 type 0
[341409.512535] sd 15:0:0:0: [sdg] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[341409.515399] sd 15:0:0:0: [sdg] Write Protect is off
[341409.515407] sd 15:0:0:0: [sdg] Mode Sense: 53 00 00 08
[341409.518240] sd 15:0:0:0: [sdg] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[341409.528580]  sdg: sdg1
[341409.534874] sd 15:0:0:0: [sdg] Attached SCSI disk
However, the Pinebook Pro recognizes the enclosure when plugged in to a USB 3 port, assigning it the device file /dev/sda, but gnome-disks reports "No Media".  dmesg reports:
[ 1490.403480] usb 2-1.1: new high-speed USB device number 4 using ehci-platform
[ 1490.564908] usb 2-1.1: New USB device found, idVendor=152d, idProduct=0562, bcdDevice= 2.06
[ 1490.565662] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1490.566313] usb 2-1.1: Product: SSK Storage
[ 1490.566693] usb 2-1.1: Manufacturer: SSK
[ 1490.567050] usb 2-1.1: SerialNumber: DF56419883E5B
[ 1490.569695] scsi host0: uas
[ 1490.571524] scsi 0:0:0:0: Direct-Access     SSK                       0206 PQ: 0 ANSI: 6
[ 1490.573978] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1499.433316] sd 0:0:0:0: [sda] Unit Not Ready
[ 1499.433767] sd 0:0:0:0: [sda] Sense Key : Hardware Error [current]
[ 1499.434347] sd 0:0:0:0: [sda] ASC=0x44 <<vendor>>ASCQ=0x81
[ 1499.435414] sd 0:0:0:0: [sda] Read Capacity(16) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 1499.436252] sd 0:0:0:0: [sda] Sense Key : Hardware Error [current]
[ 1499.436829] sd 0:0:0:0: [sda] ASC=0x44 <<vendor>>ASCQ=0x81
[ 1499.437890] sd 0:0:0:0: [sda] Read Capacity(10) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 1499.438720] sd 0:0:0:0: [sda] Sense Key : Hardware Error [current]
[ 1499.439285] sd 0:0:0:0: [sda] ASC=0x44 <<vendor>>ASCQ=0x81
[ 1499.440892] sd 0:0:0:0: [sda] 0 512-byte logical blocks: (0 B/0 B)
[ 1499.441442] sd 0:0:0:0: [sda] 0-byte physical blocks
[ 1499.442261] sd 0:0:0:0: [sda] Test WP failed, assume Write Enabled
[ 1499.443012] sd 0:0:0:0: [sda] Asking for cache data failed
[ 1499.443537] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 1499.444514] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of physical block size (0 bytes)
[ 1499.485275] sd 0:0:0:0: [sda] Unit Not Ready
[ 1499.485675] sd 0:0:0:0: [sda] Sense Key : Hardware Error [current]
[ 1499.486252] sd 0:0:0:0: [sda] ASC=0x44 <<vendor>>ASCQ=0x81
[ 1499.487290] sd 0:0:0:0: [sda] Read Capacity(16) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 1499.488131] sd 0:0:0:0: [sda] Sense Key : Hardware Error [current]
[ 1499.488711] sd 0:0:0:0: [sda] ASC=0x44 <<vendor>>ASCQ=0x81
[ 1499.489911] sd 0:0:0:0: [sda] Read Capacity(10) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 1499.490756] sd 0:0:0:0: [sda] Sense Key : Hardware Error [current]
[ 1499.491336] sd 0:0:0:0: [sda] ASC=0x44 <<vendor>>ASCQ=0x81
[ 1499.494885] sd 0:0:0:0: [sda] Attached SCSI disk
I note that there is a package named nvme-cli, is this necessary?
Same problem with the default operating system, and with an install of the Mandriva KDE image.
Is this the problem: [ 1499.490756] sd 0:0:0:0: [sda] Sense Key : Hardware Error [current], is the Pinebook Pro not capable of supplying sufficient current for this device?
Thanks for any ideas offered!
(12-28-2019, 02:10 PM)mgchristensen Wrote: I have a Samsung 970 EVO SSD 1TB - M.2 NVMe in a SSK Aluminum M.2 NVME external case, see here for the product on Amazon: https://www.amazon.com/gp/product/B07MNF...UTF8&psc=1
dmesg reports:
Did you notice that on the machine on  which it works, the uas driver isn't being used,  but on the pinebookpro, it is.  I know that in some past cases,  some types of drives/controllers needed to be blacklisted from using uas . Don't know if that is still the case.
It seems that the pinebookpro sees the drive and gets its serial no.
First,  if you put it back on the other machine,  does it still work?  (Just asking in case it was accidentally remove while mounted, or came lose in the adapter)
If it does,  I would try it on other USB ports on the Pinebookpro.  I believe it comes with two cables?  So you could try both the d and a ports?
fg.  I have one of those adapters which I haven't tried yet.  I'm curious,  if you wanted to use the nvme in another machine, not in the adapter,  are you able to remove the head exchanger pad from it?  If you can I can try with  a Samsung 981 in the adapter on the pinebookpro.
The nvme-cli package lets you control and monitor certain aspects of the disk,  load firmware,  etc.  but you do not need it to make the disk
work.
If you google that sense key error,  you will see that it has been happening in various circumstances for a number of years, none of which appear to have anything to do with actual current..but who knows.
@mgchristensen, You may want to see if you can reduce the maximum power. We have brief instructions on the Wiki;
Wiki - Pinebook Pro - Post NVMe install power limiting
I don't know if MS-Windows allows this, though I would assume so. It might be buried in some tool or vendor software.
As usual for the Wiki, feel free to correct, improve or comment, (good or politely bad).
Arwen Evenstar
Princess of Rivendale
A correction: I tried Manjaro Linux, not Mandriva (don't know where of how Mandriva popped into my head).
belfastraven, in answer to some of your questions/suggestions:
Drive appears to be unchanged when I connect it back to my workstation after the failure to be recognized by the Pinebook Pro.
Same results on the USB C port and either of the USB 3 ports.
Tried blacklisting the uas module via the file /etc/modprobe.d/modprobe.conf containing the single line "blacklist uas". Did not work. However, sudo modprobe uas and sudo modprobe usb_storage both do not load the modules.  Is this a difference between x86_64 world and ARM world?
Maybe something like here: https://bbs.archlinux.org/viewtopic.php?id=142202 is needed, removing the driver (if it is present) from initramfs?  or is this another difference between x86_64 and ARM worlds with no initramfs in ARM world?
Arwen, thank you, the drive gets real toasty in its external case when connected to the Pinebook Pro, but not when connected to my workstation.  "nvme list" however does not recognize it as a NVMe drive in the external case. I want to try it as an internal drive, but I (old man) fat-fingered the tiny cable connector on the main board and broke it.  That will teach me not to use my magnifiers and a lighter touch!
II think the usb drivers (including uas) are compiled into the kernel and are not modules.
I believe you can blacklist by adding to the setenv line in boot.txt (if on manjaro)
usb-storage.quirks=xxxx:xxxx:u (where the xxxx:xxxx is the usd id from lsusb) and (on manjaro) running ./mkscr. (for my device id is 152d:0562) . it's actually the contoller you are blacklisting from uas.
That indeed worked to blacklist uas for the device. Adding that storage quirk won't bother anything else you are using on the system.
In my case, however, I think I somehow killed the nvme since it is not seen to my desktop either right now. (I not only have problematic fingers, but, apparently a problematic brain) I know in the past that there have been problems with the JMicron controllers (which the adapter has) on linux. People seem to be having better luck with the 563 controllers -- this device is 562, at least in my case.
Re the heat, as Arwen indicated, you may want to try to limit the power. You can probably do that from Fedora on your workstation. If you don't limit power usage, you may have the issue previously mentioned here that if the battery is low, you may not be able to boot.
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 781 05-06-2024, 09:27 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 380 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 325 02-17-2024, 07:06 PM
  New Working nVME gilwood 0 264 02-12-2024, 08:46 AM
Last Post: gilwood
  Pinebook Pro charging issues tomekdev 1 666 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,178 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 132,168 09-13-2023, 03:43 AM
Last Post: k3dAR
  NVME problems 2022 / Intel 660p 1TB Starbug 1 1,604 04-04-2023, 12:16 PM
Last Post: globaltree
  PineBook Pro dead ottahe 9 6,165 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,591 12-27-2022, 03:31 PM
Last Post: samtux
