Can I rewrite a non-bootable eMMC from the PBP itself?
I was playing with different OS images and decided that since I was able to successfully boot from SD card it would be OK to overwrite the eMMC module image.
I dd'ed a Rock64Pro (bionic-minal arm64) onto the eMMC and now it won't boot anymore, neither from eMMC nor SD.
I was able to eventually start from SD by disabling the eMMC via the internal switch, but since I can't see it I cannot write to it.
How can enable the eMMC but bypass it at boot in order to rewrite it from the PBP itself (I don't have any other equipment to which I can attach the eMMC).
I have enabled the serial connector and do have a serial console adapter that I can connect to a Linux box, and probably attach to via minicom.
I believe in some other posts I have seen, you can re-activate the eMMC switch after booting. (?)
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
I was able to interrupt the boot sequence via serial console.
I can now boot from my SD and see the eMMC block device, so I should be able to write a new image onto it from there Smile
For others that may be reading this thread, here is a reference to the eMMC disable switch;
Wiki - Pinebook Pro - Key Internal Parts
Eventually we will get a clearer idea of how to use the eMMC disable switch. I vaguely recall someone saying that you start the PBP with the eMMC disabled, wait a few seconds, and then switch it back to enabled. Thus, you would be able to boot off a SD card and then fix the eMMC. Requires the bottom to be open... but better than a brick :-).
Arwen Evenstar
Princess of Rivendale
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 60,456 11-20-2023, 06:22 PM
  Selling my Pinebook Pro with a bootable NVMe WD SSD drive pinemouth 0 766 09-27-2023, 08:53 PM
Last Post: pinemouth
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 1,503 04-23-2023, 06:58 AM
Last Post: acruhl
  Doesn’t power on after flashing emmc badguru 3 1,264 02-25-2023, 09:00 PM
Last Post: badguru
  eMMC problem with Tow-Boot/u-boot on SPI repa 3 1,731 02-21-2023, 01:49 AM
Last Post: repa
  Partial boot after installing Manjaro on emmc regivanx 11 3,206 02-06-2023, 09:11 AM
  Unable to Boot anything (emmc or SDcard) line72 5 2,038 01-17-2023, 12:07 PM
Last Post: nfms
  how to make a bootable USB linux sine pinebook will not boot up River 14 4,862 12-11-2022, 11:12 PM
  What OS have you recently flashed onto PBP eMMC? jcun4128 6 2,401 11-26-2022, 09:39 AM
  Unable to boot from emmc after flashing it rfm83 3 1,812 11-08-2022, 10:59 PM
Last Post: rfm83
