Linux Mint?
(11-04-2019, 07:16 AM)Wizzard Wrote: Here https://forum.pine64.org/showthread.php?tid=8119
Please, how do I make this image?
I tried putting it on SD card (32GB) with Etcher and Rufus, but it boots only into original Debian Mate from EMMC and mounts the 2 partitions from SD card (boot and linux or something like that)
Have you run the update script in Debian?
I don't know that (I'm a noob)..
I remember I did run before on Debian
    apt-get update
    apt-get dist-upgrade
    apt-get update
In the default Debian install, there is a notifier icon in the bottom panel that runs a script for updating the system. I think it appears as a small circle with 2 orbiting arrows.
    apt-get update
I don't see it, I only see something similar in the top left corner near "applications" menu, but it only shows the "application" options...
The sound on my PBP Debian Mate is not working, I did search last week for that option to update the system but just didn't see it anywhere.
(EDIT I'm logged in as root(
(11-12-2019, 08:27 AM)ivek Wrote: Please, how do I make this image?
    apt-get update
I'm not sure if it's visible while logged in as root. It might be worth a try to check logged in as your normal user.
(11-12-2019, 08:30 AM)Wizzard Wrote: Have you run the update script in Debian?
    apt-get update
WOW, everything is different as a normal user, I only tried root cuz that was the first thing that came to mind when I gotten it...
Tx, guys, now can I try Ubuntu build from the memory card?
Glad you got it figured out! Yes, you should be able to boot from SD now
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 335 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,480 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 660 07-13-2023, 05:21 PM
Last Post: owaspfap
  Kali Linux for Pinebook Pro Luke 100 159,299 05-03-2023, 06:10 AM
Last Post: dachalife
  DiY - Installing Void Linux ARM On The Pinebook Pro vincele 1 1,202 11-28-2022, 05:03 PM
  Arch Linux ARM root filesystem SKiljan 24 20,823 09-24-2022, 03:11 AM
Last Post: alexandre
Information Install Void Linux with near-full-disk encryption dumetrulo 3 3,080 09-05-2022, 12:00 PM
Last Post: petersen77
  Help with Kali Linux wifi not working but works with Manjaro PineSupporter 2 2,381 08-25-2022, 02:15 PM
Last Post: Niko
  Problems installing/ booting a different Linux on PinebookPro v-man 3 3,083 03-22-2022, 06:37 PM
Last Post: pentamassiv
Sad 1080p60 video on PBP Linux chewie 2 3,035 08-03-2021, 09:43 AM
Last Post: chewie
