Pinebook Pro won't turn on
I just received my Pinebook Pro. I opened the box, and hit the power button, but nothing happens. I plugged the charger in, and I see a tiny LED near the barrel connector that is red, but then it turns off after about a minute. No other lights come on, and after a half hour of being plugged into the charger, the unit still won't power on. Any suggestions?
(10-31-2019, 01:52 PM)codebreaker Wrote: I just received my Pinebook Pro. I opened the box, and hit the power button, but nothing happens. I plugged the charger in, and I see a tiny LED near the barrel connector that is red, but then it turns off after about a minute. No other lights come on, and after a half hour of being plugged into the charger, the unit still won't power on. Any suggestions?
How did you hit that button? Short or long hit?
Odoslané z ONEPLUS A5010 pomocou Tapatalku
Both. A tap, and a long hold.
A tap won't turn it on, a press about a second turns it on.
If I understand correctly, the power led should remain lit while connected to the power supply.
I'm having the same issue. Long press, 1 second press, tap, etc, nothing works. I'm wondering if something wasn't connected correctly inside.
Same issue.  Red light by the barrel, but no other indication of power.  Short presses, long presses, no activity on the panel display or keyboard lights
I'm going to remove the back panel tomorrow morning and see if everything is connected properly.
(11-01-2019, 06:51 PM)GLSRacer Wrote: I'm going to remove the back panel tomorrow morning and see if everything is connected properly.
I'm looking at mine now, and everything seems to connected.  I even tried disconnecting the battery and connecting the bypass.  Still didn't power on.
I even removed AC power, Disconnected the bypass, replaced the battery, and held down the power switch for 30 secs.  Still nothing
Success! I reseated the eMMC again with a bit more force and this time there was a more positive click. I then hit the reset button on the board and the laptop booted up.
(11-01-2019, 08:09 PM)GLSRacer Wrote: Success! I reseated the eMMC again with a bit more force and this time there was a more positive click. I then hit the reset button on the board and the laptop booted up.
I just tried the same thing, and I didn't have any success   Sad
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 746 05-06-2024, 09:27 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 380 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 325 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 661 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,167 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 131,856 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 6,148 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,578 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 138,192 11-30-2022, 04:28 PM
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 1,970 10-21-2022, 07:57 AM
Last Post: dachalife
