Pinebook left USB port not working - while right port does.
I have tried several devices (mouse and jump drives) in left USB port, with no function at all (although it seems to be powering the mouse laser, with flickering). This is after installing latest stable (supported) Armbian.
The right USB port functions normally.
The left port seemed to work with the initial Android OS, though Android was unable to read the Linux image on that USB drive.
I did install the 'mini firmware package' using Armbian-config -> [System and third-party software] -> [Mini] (if that is relevant).
Thanks for any help regaining the lost USB port.
(08-03-2019, 10:17 PM)armhfadillo Wrote: I have tried several devices (mouse and jump drives) in left USB port, with no function at all (although it seems to be powering the mouse laser, with flickering).  This is after installing latest stable (supported) Armbian.
Surely the only way to be absolutely certain if this is a hardware or software issue is to reload the original distro that was on the PineBook to start with (KDE Neon?).
If everything works as it should with the original software then it will be 100% an Armbian problem with much relief that the hardware is ok. Smile
Obviously if it doesn't work with KDE Neon than you have a hardware problem  Sad
Thank you neilman. I may boot another OS from SD card to try that out. Good idea.
As I said, I think I did get some function from the "dead" port with Android. So that is plenty of reason for hope.
Thanks in advance to anyone who looks into a probable USB driver issue with Armbian.
  Dead Pinebook - fix it or spare parts? oloturia 2 2,298 03-19-2023, 03:38 PM
Last Post: oloturia
  Broken bottom case of PineBook 14 Mick 1 992 02-22-2023, 05:49 AM
Last Post: Mick
  Original 14" Pinebook an Orphan? vdicarlo 2 1,344 01-05-2023, 10:42 AM
Last Post: jezek
  Pinebook Users are a nobody leperotero 13 13,016 09-06-2022, 09:29 PM
Last Post: zapper
  Does anybody repair pinebook pro laptops for a fee? Tsvi Bar-David 0 1,025 09-05-2022, 07:49 PM
Last Post: Tsvi Bar-David
  Pinebook with a broken screen and 2 eMMC's for sale. UK ONLY. frank-zappa 0 1,658 03-08-2022, 10:14 AM
Last Post: frank-zappa
  Pinebook to Pinebook Pro-esque upgrade kit sebboh 5 7,688 08-18-2021, 11:01 PM
Last Post: Corkonian
  new pinebook help ron_burgundy 5 7,852 12-17-2020, 04:54 PM
Last Post: ron_burgundy
  Few questions about flashing to a MicroSD card on the Pinebook Pro SanjevR 6 9,803 12-07-2020, 04:02 PM
Last Post: SanjevR
  TOR Browser on the Pinebook Pro jay3gg 0 3,033 11-16-2020, 01:25 AM
Last Post: jay3gg
