Few questions about flashing to a MicroSD card on the Pinebook Pro
Hey all so I purchased another Pinephone and I want to flash an OS to my microSD card. Previously to flash I used my Mac Laptop and it required an acessory with a USB cable to connect the microsd to the laptop. Now I don't want to use a mac but rather i'd like to use my Pinebook Pro since I am trying to make this my main computer. It does seem that the pinebook Pro has a slot for sd cards but it doesn't appear to have anything for MicroSD cards. Another questions I have is it seems that I can't find Balena Etcher in the pacmac-manager. How do I download it?
(11-25-2020, 05:15 PM)SanjevR Wrote: Hey all so I purchased another Pinephone and I want to flash an OS to my microSD card. Previously to flash I used my Mac Laptop and it required an acessory with a USB cable to connect the microsd to the laptop. Now I don't want to use a mac but rather i'd like to use my Pinebook Pro since I am trying to make this my main computer. It does seem that the pinebook Pro has a slot for sd cards but it doesn't appear to have anything for MicroSD cards. Another questions I have is it seems that I can't find Balena Etcher in the pacmac-manager. How do I download it?
The Pinebook Pro does use a 'micro sd' card,  though when discussing it we often just refer to it as an 'sd' card.
It may be handy to use a 'usb to micro sd adapter' instead of the onboard micro sd card slot,  as your PBP will attempt to boot from this
if it is still inserted when you do a reboot, or a start-up.
I have not 'seen' the Balena Etcher app offered for the PBP's operating systems "yet",  currently I use an old Dell laptop running LMDE (Linux Mint Debian Edition)
to flash the 'sd' cards for my multiple Pine phones.  Both of my PBP's are still running the original 'mrfixit' Debian.
'Etcher has been very dependable for me,  flashing sd cards for both the PBP's and the Pine phones.
How do I get an etcher or a etcher equivalent program on the pinebook pro? I don't want to use other laptops to flash i want to use my pinebook pro
I tried to install the etcher using the build from this link https://github.com/futurejones/balena-et.../README.md instead of using apt-get i used pacman - Syu balena-etcher-electron because the apt-get command was not found.
What am I doing wrong?
Is there anything equivalent to this that I can use to flash a microsd card using my pinebook pro. Please Help
What operating system are you running on your Pinebook Pro ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(11-30-2020, 06:58 PM)bcnaz Wrote: What operating system are you running on your Pinebook Pro ?
I'm not sure. Whatever the default operating system I got when I purchased it from this site.
Where do I check what I operating system is?
My Pinebook Pro's were from the first batch(ISO) and second batch(ANSI),
I think Pine64 has changed the operating systems that it ships "pre-installed" since then.
I would think it should be listed on the "Start-up" or "splash screen"  ?
I am planning on updating both of mine to the mainstream 'Debian Arm64' pretty soon.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
(12-05-2020, 05:32 PM)bcnaz Wrote: My Pinebook Pro's were from the first batch(ISO) and second batch(ANSI),
I ordered my pinebook pro and it came a few months ago I think it came in June 2020. I have also found the Operating system information in the information center. Here's what I found
Manjaro-ARM
Software
KDE Plasma Version: 5.20.3
KDE Frameworks Version: 5.76.0
Qt Version: 5.15.1
Kernel Version: 5.7.19-1-MANJARO-ARM
OS Type: 64-bit
Hardware
Processors: 6 x
Memory: 3.7 GiB of RAM
Graphics Processor: Mali T860
Please note I have no idea what any of that meant not KDE plasma version, not KDE Frameworks or Kernel Version or anything LOL I wouldn't mind if someone explained all that to me.
  Dead Pinebook - fix it or spare parts? oloturia 2 7,396 03-19-2023, 03:38 PM
Last Post: oloturia
  Broken bottom case of PineBook 14 Mick 1 4,780 02-22-2023, 05:49 AM
Last Post: Mick
  Original 14" Pinebook an Orphan? vdicarlo 2 6,046 01-05-2023, 10:42 AM
Last Post: jezek
  Pinebook Users are a nobody leperotero 13 27,364 09-06-2022, 09:29 PM
Last Post: zapper
  Does anybody repair pinebook pro laptops for a fee? Tsvi Bar-David 0 4,302 09-05-2022, 07:49 PM
Last Post: Tsvi Bar-David
  Pinebook with a broken screen and 2 eMMC's for sale. UK ONLY. frank-zappa 0 5,198 03-08-2022, 10:14 AM
Last Post: frank-zappa
  Pinebook to Pinebook Pro-esque upgrade kit sebboh 5 13,685 08-18-2021, 11:01 PM
Last Post: Corkonian
  new pinebook help ron_burgundy 5 14,683 12-17-2020, 04:54 PM
Last Post: ron_burgundy
  TOR Browser on the Pinebook Pro jay3gg 0 5,625 11-16-2020, 01:25 AM
Last Post: jay3gg
  Pinebook doesn't charge anymore Reinoud 4 12,821 11-15-2020, 10:26 PM
Last Post: pagesix1536
